IPR year tool - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Tte531
post #1 of 4 (permalink) Old 03-16-2019, 03:21 AM Thread Starter
IPR year tool
This may already be documented and if so please just delete this. Also title should say IPR Test Tool. Drink to much and try to be productive... this is what you get.
If not! Then I made my own IPR test tool for a whooping $44.
There are a few you can but ranging for 88$ on eBay to 200$ at some places. If your a DIYre like myself then if anything this should last all the time Ill need it.
So I bought the IPR test fitting off amazon for $10. The I went over to Home Depot and bought the following.
Then once I went through the extensive 5min assembly, I got this.
Turd-250 and 207RIDER like this.
2003 Excursion EB 6.0 PSD: BPD Oil Cooler, Water Pump, 7.3 fan adapter: Adrenaline Stock HPOP: APR Head Studs (One at a time): KC Turbo Billet Compressor: EGR Delete: Sinister Coolant Filter & Regulated Fuel Return: '08+ Oil Pan/Filter: SCT LiveWire TS+
Tte531 is offline
post #2 of 4 (permalink) Old 03-16-2019, 11:00 AM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: IPR year tool
I'm Turd, and I approve this message
lol but seriously, thanks for posting this!
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 4 (permalink) Old 03-16-2019, 01:43 PM
"resident smarty pants"
Re: IPR year tool
Thanks for the post!
Mark
bismic1 is offline
post #4 of 4 (permalink) Old 03-18-2019, 02:51 AM Thread Starter
Re: IPR year tool
Finally got to test it out. Worked like a charm!
I never read to do this until stuff was hitting the fan... if it were me Id do this test any time I made a change that affected the HPO system. Shoot if I had done this when I put new seals on the injectors I might not have had to tear it down again...
Tte531 is offline
Similar Threads
Late year/ New Year GTG???? HeavyAssault Mid-Atlantic (MD, N.C. , PA, S.C. , WV, VA) 33 12-15-2011 04:12 PM
Third Brake Light, I need some help - different designs from year to year Headcase98002 1994-1997 General Aftermarket 13 05-05-2011 10:54 PM
First breakage of year comes at last pull of year House Sled Pulling 20 10-31-2008 07:56 PM
