06 6.0 won't start - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 23 (permalink) Old 03-09-2019, 09:03 PM Thread Starter
06 6.0 won't start
Twice my 2006 F250 6.0 stalled and wouldn't restart until the next day when it started right up. Third time no go. Crank and no start. Got a scan gauge and while cranking find FICM at 48 volts, IRP at 84.5%, SYN at 1, and ICP at 0. Replaced the ICP Sensor to no avail. Before I dig deeper under the hood and replace the IRP valve I would like some advice. I am told it it unlikely it is the pump in a 2006. Please help.
Smills48 is offline
post #2 of 23 (permalink) Old 03-09-2019, 09:18 PM
"resident smarty pants"
Re: 06 6.0 won't start
You need to do an air test to pinpoint the leak in the high pressure oil system. Could be the HPOP discharge (STC) fitting, or the standpipes, or the dummy plugs (assuming these parts are all still original).
Could also be the IPR valve.
Best way to do an air test (IMO) is to order the IPR fitting so you can remove the IPR and air test from that "port/fitting". You can air test through the ICP sensor port also (it is easy to get to), but sometimes a leaking IPR valve makes pinpointing a leak somewhat difficult (assuming you do have a leak somewhere else). Also, you have to close the IPR valve for the air test when you supply air through the ICP sensor port.
Mark
bismic1 is offline
post #3 of 23 (permalink) Old 03-09-2019, 11:30 PM Thread Starter
Thanks for your thoughtful and detailed responce. My challenge is dealing with this challenge in my driveway in rural Maine mid winter. Don't know how to perform an air test with my resources. IN the interest of throwing money at the problem, where do i throw first. My apologies to those who work with these issues unabridged.
Smills48 is offline
post #4 of 23 (permalink) Old 03-09-2019, 11:37 PM
matthewd11's Avatar
Do you have base oil pressure when it won’t start? Are you using an OEM filter?
Even with a full open IPR you should still have about 150psi of pressure. Have you replaced the STC fitting?
Whereabouts in Maine? My family has 12 acres in brownfield, and we often escape to the Allagash wildnerness waterway in the summer.
matthewd11 is offline
post #5 of 23 (permalink) Old 03-10-2019, 12:51 AM
These modern day diesels can get complicated. You can spend a LOT of money if you don;t do the proper troubleshooting.
Air pressure testing:
Mark
bismic1 is offline
post #6 of 23 (permalink) Old 03-10-2019, 12:57 AM
Testing through the ICP sensor requires closing the IPR valve. There are several ways to do it, but you need to either "backprobe" a PCM connector or rig up a connector for your IPR valve that can supply 12V (pos and neg) to the valve.
To do the air test, you get a better test if you listen for the leaks with the valve covers off (for injector leaks), but you also need to listen for the air leaks at the oil fill tube, turbo oil drain tube, the CCV opening, and at the oil filter housing (filter removed).
The dummy plugs and standpipes are known leak points. They are under the valve covers (in the oil rails).
The HPOP STC fitting is harder to upgrade.
Simple searches will reveal videos on doing all of this.
The problem is that you need some tools and mechanical experience to do this work. If you can't do the work, then you will probably be at the mercy of a shop treating you honestly. Most do, but some don't. If a shop tells you that you need an HPOP, then I start to get suspicious. The 05-07 HPOP's are fairly reliable and changing them out when they don't need to be is far too common.
Mark
bismic1 is offline
post #7 of 23 (permalink) Old 03-10-2019, 01:04 AM
Personally I like the method of air testing through the IPR port (IPR removed), but it is a little harder to get to than the ICP on the late 04-07 model years:
https://www.dieseltechmag.com/2015/0...-air-test-tool
Mark
bismic1 is offline
post #8 of 23 (permalink) Old 03-10-2019, 11:49 AM Thread Starter
Mathewd11, I'll have to check base oil pressure. Yes I use OEM filters. I'll have to research the STC fitting.
I live in Rumford. Alligash is a nice area.
Smills48 is offline
post #9 of 23 (permalink) Old 03-10-2019, 11:52 AM Thread Starter
Bismic1, thanks for the additions. I'm fine doing the work, I would rather do it in a heated garage though. I'll research your suggestions and see what I come up with. Thanks.
Smills48 is offline
Similar Threads
Won't start 06 6.0 MattFoster55 6.0L Power Stroke Technical Info 2 08-10-2014 03:18 AM
Wait to start light blinks ,won't start Lonnieford 7.3L Power Stroke Technical Info 0 06-28-2014 06:51 PM
We won!! We won!! We won!!! lubeowner 6.4L Power Stroke - Aftermarket & Performance 40 08-10-2010 04:29 PM
Extended start, low on power, won't start when cold Ripsaw 7.3L Power Stroke Technical Info 17 03-21-2009 04:08 AM
Hard to start... now won't start... johnny0874 6.9 - 7.3L IDI Diesels 83-93 Model Years 8 03-12-2009 09:56 AM
