2003 Ex 6.0 Smoke from engine - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-06-2019, 06:59 PM Thread Starter
Hey,
Ive got a 2003 Ex 6.0 with 59k miles that i just finished addressing all the major issues that plague a 6.0. See my Sig..
When i went to start the truck up it took alot of cranking to get it where it would fire. Once it started up i got a bunch of white smoke from under the hood maybe back where the turbo is. I was concerned at first that i had pinched a wire and something was shorting out. However, this only happened when it was running. (nothing like thinking you're about to burn your vehicle down)
Im beginning to think maybe i just dont have the turbo clamps on well enough or they just haven't seated themselves fully yet. Then what im seeing is just the engine cleaning out whats in the cylinders from all the cranking and its seeping past the turbo clamp seals.
That sound legit lol
2003 Excursion EB 6.0 PSD: BPD Oil Cooler, Water Pump, 7.3 fan adapter: Adrenaline Stock HPOP: APR Head Studs (One at a time): KC Turbo Billet Compressor: EGR Delete: Sinister Coolant Filter & Regulated Fuel Return: '08+ Oil Pan/Filter: SCT LiveWire TS+
Tte531 is offline
post #2 of 3 (permalink) Old 03-07-2019, 03:11 AM
Re: 2003 Ex 6.0 Smoke from engine
the smoke issue was only one time? as far as the long start that is not alarming as long it was just the initial start, starts ok now? does it have any driveabilty issues? You should not have had a "bunch" of smoke in the turbo area. What kind of egr delete? blanking discs? The clamps should seal pretty good even if they are under tightned, so unless they are very loose dont try to try an tighten your way out of big leak. Your misalignment theory sounds most likely. look at some utube's for clamp tightening (or turbo install).
2003 (03.25MY) 250 super duty xlt, auto, 2wd, 147K owned since new, word done; Cooling system flush and fill with ECL-1 coolant, coolant filter, oem oil cooler, BP EGR cooler, turbo rebuild and powermax GT40 compressor, dieselsite cacc boots hot side, cat delete, blue spring kit, transmissison fliter upgrade to 08 style, Edge monitor (no tuner).
knotreel is offline
post #3 of 3 (permalink) Old 03-07-2019, 03:45 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Having cranked over many a 6.0 after invasive surgery, I wouldn't worry about it at all.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
Similar Threads
2003 suddenly dumping smoke Toreador250 6.0L Power Stroke Technical Info 5 04-07-2015 12:02 AM
2003 7.3 low boost very low egt no smoke help me! kfales 7.3L Power Stroke Technical Info 1 12-05-2013 09:29 PM
02 Ex engine hurt CtG 7.3L Power Stroke Technical Info 1 04-10-2013 09:29 AM
2001 Ex "service engine soon". Running on one leg... JoJo Power Stroke Excursions 15 11-18-2012 12:34 AM
2003 excursion blowing white smoke johnnie 7.3L Power Stroke Technical Info 1 07-14-2010 03:01 AM
