Cracked degas blew coolant on ficm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-01-2019, 02:03 AM Thread Starter
04 F550 6.0 - Driving it down the road under heavy load, died and within seconds noticed steam coming from under the hood. The degas bottle developed a crack and small hole and blew hot coolant all over the ficm.
No start, no smoke. Autogenuity reports U0306. We took the ficm out of a 06 F250 6.0 and try it on the truck. No start, but no codes. Put the 550 ficm in the 06 and same code.
I'm guessing the ficm was fried. Auto genuity is reading ficm voltage 12v and 48v but obviously and issue w it.
I still can't figure out why the 550 won't start w the 250 ficm. I'm thinking that we might have also fried the ficm harness to one side or the other or both.
Anyone have any thoughts?
Craig Maffet is offline
post #2 of 2 (permalink) Old 03-03-2019, 01:55 PM
Re: Cracked degas blew coolant on ficm
It is possible that the PCM could have been affected. Maybe you could do an injector buzz test with the AE which might help to move the issue along.
2003 (03.25MY) 250 super duty xlt, auto, 2wd, 147K owned since new, word done; Cooling system flush and fill with ECL-1 coolant, coolant filter, oem oil cooler, BP EGR cooler, turbo rebuild and powermax GT40 compressor, dieselsite cacc boots hot side, cat delete, blue spring kit, transmissison fliter upgrade to 08 style, Edge monitor (no tuner).
knotreel is offline
Similar Threads
A More Durable Degas: Mishimoto’s 6.0L Aluminum Degas Bottle R&D Mishimoto 6.0L Power Stroke - Aftermarket & Performance 44 11-30-2016 05:36 PM
Coolant line blew Powerstroke6714 11-16 6.7L Power Stroke Technical Info 0 05-04-2015 12:51 AM
Degas bottle cracked - Rotella Related? Ontarioford 6.0L Power Stroke Technical Info 15 12-28-2012 10:26 PM
coolant degas bottle overflow jl250sd 6.0L Power Stroke Technical Info 7 01-21-2012 03:07 PM
Coolant ejecting from degas bottle offroad diesel 1994-1997 Power Stroke Technical Info 8 10-17-2009 01:48 AM
