Ebp readings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-26-2019, 12:15 AM Thread Starter
Ebp readings
What should be the ebp readings on my 6.0? My sct livewire only shows psi on the pid. It reads whatever my boost psi is. If my boost is 0 then ebp shows 0 and so on. Has a non vgt turbo on it. Any suggestions?
Maroon stroken is offline
post #2 of 5 (permalink) Old 02-27-2019, 08:30 PM
Re: Ebp readings
it should be more than the boost.
2003 (03.25MY) 250 super duty xlt, auto, 2wd, 147K owned since new, word done; Cooling system flush and fill with ECL-1 coolant, coolant filter, oem oil cooler, BP EGR cooler, turbo rebuild and powermax GT40 compressor, dieselsite cacc boots hot side, cat delete, blue spring kit, transmissison fliter upgrade to 08 style, Edge monitor (no tuner).
knotreel is offline
post #3 of 5 (permalink) Old 02-27-2019, 11:32 PM Thread Starter
Any suggestions?
post #4 of 5 (permalink) Old 02-28-2019, 12:58 PM
Weatherlite's Avatar
Garage
Re: Ebp readings
Honestly, it varies quite a bit and will change based on engine speed, load, and so on. Also, depending on how your PIDs are configured, you could get a couple different readings....might show around 14PSI with everything off, or might show zero. That will affect the rest of the readings, of course. Mine would show zero with engine off, and about 15 at idle, with it increasing to around 50 during higher throttle. (I think....it's been a while since I've looked) However, it shouldn't matter to you at all. The only reason that's of any real value is for the VGT. If you have a non-VGT turbo, who cares what it is? Unless you're just curious.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #5 of 5 (permalink) Old 02-28-2019, 10:59 PM Thread Starter
Oh ok thanks. I just didn't know if it had anything to do with the fuel mapping.
Similar Threads
EBP readings OBSisbest 6.0L Power Stroke Technical Info 1 09-01-2014 03:51 AM
EBP Absolute Readings on 275 & 310? [email protected] 6.4L Power Stroke - Aftermarket & Performance 35 02-18-2010 03:13 AM
Scanner Torque Readings? TERRCO General Questions & Discussion 0 06-12-2008 03:11 AM
Isspro Gauge readings, tell me if this is normal Doakster 7.3L Power Stroke - Aftermarket & Performance 3 01-25-2008 10:57 PM
