Scanguage 2 reading for 2006 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-23-2019, 03:16 AM Thread Starter
Hey guys, just got a scanguage-2 from BPD pre programmed and took my truck for a 90 mile round trip drive. Outside temp right at 30 degrees here in Idaho and my EOT never got above 140 and ECT 123 on flat ground doing 55 MPH.
FMP- 47.5 - 48
CPM- .174
HPR- 36.9
FLP- 13.5
FVP- 14.0
ICP- 1182
IPR- 36.4
VGT- 53
TFT- 131
EBP- 28.4
FSS- 527
TFC- 5.48
MAP- 21.3
When driving up the hill that leads to my property, my EOT- is 192 and ECT- is 190. Is the outside temp having a effect on the EOT and ECT on flat ground? Any thoughts from some experts would be greatly appreciated.
roughneckisi is offline
post #2 of 4 (permalink) Old 02-23-2019, 09:48 AM
"resident smarty pants"
Re: Scanguage 2 reading for 2006
Any engine driven for 15 minutes or more is going to be warmed up. You are not going to see 123*F coolant on a warmed up engine. You have something else going on, unless you have an air cooler oil cooler that you forgot to mention.
Mark
bismic1 is offline
post #3 of 4 (permalink) Old 02-23-2019, 05:05 PM Thread Starter
pretty much stock truck.. i found a few threads on other sites with people having the same issue and a new t-stat in most cases remedied the problem..
post #4 of 4 (permalink) Old 02-23-2019, 05:07 PM
Good place to start for sure!
Mark
bismic1 is offline
Similar Threads
matco scanguage question-ASAP salprofish 1994-1997 Power Stroke Technical Info 6 09-09-2010 06:39 PM
scanguage tbolt 7.3L Power Stroke - Aftermarket & Performance 6 09-05-2010 06:27 AM
scanguage accuracy jimdawg185 General Questions & Discussion 0 06-27-2009 06:27 AM
Scanguage for mileage monitoring thetonka MPG - Fuel Economy Discussion 4 09-25-2007 02:05 PM
