Where's boost released - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-22-2019, 10:49 PM Thread Starter
I have a f250 with alot of performance mods. The turbo is a non vgt. There's no waste gate or bov to be found. When I spool it up and release throttle, I can hear what sounds like the typical bov sound but can't figure out where it's coming from. The reason for searching is it will not build over 28psi. When it gets to 28psi I can hear it releasing the excess pressure so something has to be adjusted to only go up to 28psi. Any suggestions?
Maroon stroken is offline
post #2 of 8 (permalink) Old 02-22-2019, 10:55 PM
"resident smarty pants"
Re: Where's boost released
Sometimes the EGR system will act like a blow-off. Assuming you no longer have an EGR system, then with a non-VGT turbo you don't have any "boost release", unless one has been added.
Mark
bismic1 is offline
post #3 of 8 (permalink) Old 02-22-2019, 11:27 PM
Master BS'er
jamiesaun's Avatar
Sent from my SM-G950U using Tapatalk
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #4 of 8 (permalink) Old 02-23-2019, 01:12 AM Thread Starter
The egr has been deleted. I've checked the intake side and the down pipe and couldn't find anything.
post #5 of 8 (permalink) Old 02-23-2019, 01:31 AM
Who put the non-vgt turbo on it (and why)?
And, do you know if the custom tuning was implemented to properly control a non vgt turbo?
Mark
bismic1 is offline
post #6 of 8 (permalink) Old 02-23-2019, 01:35 AM
Master BS'er
jamiesaun's Avatar
Maybe you're hearing the chocking. I'd bet that's what it is.
Brother James
post #7 of 8 (permalink) Old 02-23-2019, 01:37 AM
Master BS'er
jamiesaun's Avatar
I agree, it's not a great idea to build a boosted setup with no way to control it. Not as critical on a diesel, true. But still a bad idea.
Brother James
post #8 of 8 (permalink) Old 02-23-2019, 01:53 PM Thread Starter
Turbo was on it when I got it. Idk on the tune but it's a dyno tune. It still throws a p0046 code.
Similar Threads
New Video released of POW- John McCain Prisoner of War RampRat General Questions & Discussion 3 10-25-2008 05:53 AM
6.4 Livewire Tune Update Released! mattr66 6.4L Power Stroke - Aftermarket & Performance 11 08-07-2008 07:13 PM
new Single HPOP is released flyin hawaiian 7.3L Power Stroke - Aftermarket & Performance 36 06-17-2008 05:20 PM
Just Released!!!!.... lildevil02 7.3L Power Stroke - Aftermarket & Performance 16 10-15-2007 07:19 PM
