2006 6.0 30 sec + crank no air leaks. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-22-2019, 07:26 PM Thread Starter
Smittymv's Avatar
Im sorry if this is a repeat but im new to this site. Have an 06 6.0 fresh build. Has super extended crank to start. Runs fine once started. If you shut it off and restart still extended crank. Did air test thru irp hole. Nothing. Holds pressure for 15 mins. Is it irp stuck open partially? Dont have scan guage.
Smittymv is offline
post #2 of 3 (permalink) Old 02-22-2019, 07:29 PM
longjonsilver's Avatar
Re: 2006 6.0 30 sec + crank no air leaks.
How many miles since rebuild?
Need a scan tool of some sort to monitor what’s going on ...
longjonsilver is offline
post #3 of 3 (permalink) Old 02-22-2019, 09:30 PM
"resident smarty pants"
It isn't going to hold pressure if the IPR valve is open.
The idea isn't really to hold pressure, it is to push the oil out of the rails and listen for leaks. best to do the test w/ hot oil also (and w/ the valve covers off). That said, do you have ICP and IPR readings that say your issue is with the high pressure oil system?
In other words, do what longjonsilver posted. Get a monitor (doesn't have to be a ScangaugeII) and post data.
Mark
bismic1 is offline
Similar Threads
8 sec crank Nolo91 6.0L Power Stroke Technical Info 7 01-30-2014 05:42 AM
leaks leaks leaks Powerstrokin444 6.9 - 7.3L IDI Diesels 83-93 Model Years 5 05-28-2009 12:26 PM
.30/.30 for sale DieselPower1966 General Questions & Discussion 22 05-01-2009 08:10 PM
SEC Redfish General Questions & Discussion 7 11-21-2007 12:36 PM
