2007 6.0 odd throttle response - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-19-2019, 12:35 PM Thread Starter
I am having an issue where the truck has no throttle response until I press the pedal to a certain point. Once the pedal gets to about 25% on the PedalD sensor, the rpms will slowly increase to about 2100. If I hold the pedal steady, the rpms will drop for a bit before returning. There is no cel. I have checked the fuel pressure under load and it seems to be ok. I won't be able to work on it for another week or two but want to get some ideas for when I get the time. I have a video of the issue but can't post a link because I'm too much of a newb. Thanks
Seth Fuchs is offline
post #2 of 3 (permalink) Old 02-19-2019, 05:20 PM
Re: 2007 6.0 odd throttle response
My '06 just started doing the same thing, wondering if it might be the IPR sensor again.
rod jr is offline
post #3 of 3 (permalink) Old 02-19-2019, 07:30 PM Thread Starter
I think if it is a problem with the ipr sensor you should be able to unplug it and it will go away. Not sure though.
Similar Threads
no throttle response webb06 6.0L Power Stroke Technical Info 11 02-21-2011 03:08 AM
E99.. engine rev then no throttle response but turbo spool . . ebpv? Jsgarwood 7.3L Power Stroke Technical Info 1 01-06-2011 02:29 AM
THROTTLE RESPONSE???? 99redf350 7.3L Power Stroke Technical Info 4 09-05-2010 03:23 PM
inconsistene throttle response Hawker 7.3L Power Stroke - Aftermarket & Performance 22 10-19-2009 03:14 AM
Throttle response Ramblin'_Man 7.3L Power Stroke Technical Info 20 06-06-2008 12:06 PM
