Hard start/no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-18-2019, 05:03 PM Thread Starter
Hard start/no start
Long time lurker and I have solved many problems thanks to the help from the experts on here. Now I am at a point where I need a little advice.
Early 03, deleted, arp studs, fire ring gaskets, etc, etc.
I was getting a hard start when cold and hot. My hpop numbers were bouncing and my ipr max'd out at 85%. I had a P2291 code. Pulled parts, got back to the icp sensor. It was coated in oil, so I replaced it and the pigtail. Started up fine, drove around the block, no issues.
IPR valve was replaced about 3 years ago. Rebuilt FICM about 2 years ago.
Day after I replaced the sensor, I am sometimes getting a hard start and occasional no start when the truck is hot.
When cold I have the following before cranking:
IPR=14.7
ICP-V=0.2
FICM-V=47.5
After cranking, I get the following:
HPOP=800ish
IPR=24.7
ICP-V=1.0
FiCM-V=40-43
FICM Sync=1
When it is hot and I get a hard/no start issue, the HPOP will be around mid 300s, IPR max's out at 85%. Sometimes it will eventually build pressure and crank. Every now and then it won't.
Errors I pulled are
P0098
P0683
P2291
I have had a weak glow plug in one cylinder for a while. So I am aware of that.
I know I probably need to check for leaks, but getting back to the icp sensor just isn't fun to me.
Could IAT sensor and/or the low voltage on the FICM cause it to not be able to build pressure? I just wanted to look at some obvious options before I tore into it again.
adamdanger is offline
post #2 of 4 (permalink) Old 02-19-2019, 12:09 AM
"resident smarty pants"
Re: Hard start/no start
I would get it hot and air test, and I would air test through the IPR valve position with the IPR valve air-test fitting. Inspect the IPR valve when you remove it.
IMO the IAT sensor isn't going to cause low ICP and it is a stretch to say the FICM could. Most likely issues on an early build are IPR, HPOP, and then injectors.
Mark
bismic1 is offline
post #3 of 4 (permalink) Old 03-18-2019, 01:22 PM Thread Starter
I followed your advice on the IPR fitting. That was much easier than going through the sensor and having to energize the valve. Ended up being #3 injector top o-ring.
I ordered the Alliant kit, fought for two days and could not get the factory retaining clip out. Cried uncle and bought an oem injector. When the next injector fails, I will upgrade them all at that time. Probably to 175/30.
post #4 of 4 (permalink) Old 03-18-2019, 01:32 PM
Glad you got it done.
That is my plan too (upgrade to 175/30). I am at 210k miles, so it is probably in the near future.
Mark
bismic1 is offline
Similar Threads
Crank hard start /no start /long crank start-not covered by sticky Volkskid 7.3L Power Stroke Technical Info 5 02-07-2018 03:39 AM
No oil pressure, hard crank, no start Makeitnasty 1994-1997 Power Stroke Technical Info 2 07-11-2016 02:32 PM
04 hard to no start-no power if it does start CoryC 6.0L Power Stroke Technical Info 7 01-14-2014 04:36 PM
'03 no codes, no oil press. no start, no idea jakejamie 6.0L Power Stroke Technical Info 8 01-05-2013 05:23 AM
New at working on 6.0L no start hard start no idle leakingdieselturbo 6.0L Power Stroke Technical Info 5 01-23-2010 03:00 AM
