I need some help. And heat! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-18-2019, 04:46 PM Thread Starter
Mike/Franko88's Avatar
Okay y'all. I bought this truck used and a month later I've got no heat. Checked everything from thermostat to heater core and even everything in the glove box on. Nothing is broken, cracked, clogged or acting up. But I've got no heat out my vents. 04 6.0
Mike/Franko88 is offline
post #2 of 3 (permalink) Old 02-18-2019, 07:27 PM
matthewd11's Avatar
Are both heater hoses hot going into the heater core?
matthewd11 is offline
post #3 of 3 (permalink) Old 02-19-2019, 01:18 PM
Weatherlite's Avatar
Garage
Re: I need some help. And heat!
Stupid, I know, but have you made sure you're properly topped off?
If the engine is thoroughly warm, try running the engine up to about 1800-2000 RPMs for about a minute. While doing this, have your heater on high. If you get heat this way then you most likely have a head gasket issue, and should do a cooling system pressure test. If you get no heat, quickly go out to the engine compartment and check both heater hoses, like he said. If they are both hot, there is a problem with the blend door inside. If only one is hot then the heater core is clogged....but I've never seen that. However, if you don't have heat when revving, and both hoses are cold, then you aren't getting any flow and likely have a pump issue.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
Similar Threads
I need some heat 97psd16.5mpg 1994-1997 Power Stroke Technical Info 11 11-26-2012 08:44 PM
I have some lift questions and need some help. The 250 1999-2010 Super Duty General Aftermarket 2 09-01-2012 09:57 PM
Base Board Heat, House Too Dry, Need Help! TWIM General Questions & Discussion 7 12-06-2010 01:37 AM
No heat when stopped, heat when moving?? help please Sonic_Superduty 6.0L Power Stroke Technical Info 5 11-25-2010 03:36 AM
turbo housing discolored from heat "i need help??!!" jake_v_03 1994-1997 Power Stroke Technical Info 5 08-19-2009 07:00 PM
