Can anyone help diagnose this leak? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By masakimm
post #1 of 4 (permalink) Old 02-08-2019, 02:46 AM Thread Starter
techguy7.3's Avatar
Garage
I snapped a picture while ducking into the driver side front wheel well. The picture is looking back towards the rear of block. I’m still new to the 6.0 so not sure what I’m looking at. There appears to be 4 circular objects on block and the one closest to the firewall looks wet. It’s at top of picture right under exhaust manifol. I tried smelling it, couldn’t tell what it smelled like. I have a cold so can’t smell great right now! Hoping you can let me know what might be leaking and if it’s something to take care of ASAP or not. I peaked at the passenger side same area and it looks wet also but not as bad. Thanks!!
File Type: jpeg 029884AE-E88A-46D9-94A9-CF81AA4301AC_1549597477467.jpeg (604.3 KB, 30 views)
File Type: jpeg 8DE5EB37-46C3-4D4E-A03C-AF0CF763CA6F_1549598030470.jpeg (422.5 KB, 31 views)
techguy7.3 is offline
post #2 of 4 (permalink) Old 02-08-2019, 10:44 AM
Native Texan
masakimm's Avatar
Garage
Re: Can anyone help diagnose this leak?
looks like just oil seeping and running down the block its probably coming from the upper portion of the head which. The part circled is a freeze plug and would leak coolant which would be easily identified.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Dustybumpers likes this.
Upgrades:
masakimm is offline
post #3 of 4 (permalink) Old 02-08-2019, 10:58 AM Thread Starter
techguy7.3's Avatar
Garage
Thanks for the reply. Everything above it looks dry as far as the head goes, but then again I can’t see everything there is from the view I had.
post #4 of 4 (permalink) Old 02-08-2019, 11:49 AM
Native Texan
masakimm's Avatar
Garage
Well I have seen plenty of 6.0l in the day they can leak from the head and it is common. There is a upper aluminum portion that bolts to the head that can leak u also have the glow plug harness plugs that can leak. From what I have seen over the years that's where I would be looking.
Upgrades:
masakimm is offline
Similar Threads
SF Bay Area anyone close by that's can help diagnose? Newman Northwest (Nor Cal, OR, WA, Alaska) 0 05-06-2017 09:17 PM
How to diagnose EGR Cooler Leak YeeP 6.4L Power Stroke - Technical Info 4 02-02-2017 10:50 PM
2002 7.3 Cranks but no start after stalling. Eventually starts after sitting, mechanic can't diagnose.. e2tangovic 7.3L Power Stroke Technical Info 12 07-09-2016 07:14 PM
Can someone please help diagnose my truck?????? Jestes 7.3L Power Stroke Technical Info 8 09-07-2014 10:46 PM
Can anyone diagnose my gremlin? Dr. Kyle 6.0L Power Stroke Technical Info 3 02-12-2013 10:12 AM
