Vibration at 65-70mph? Ideas? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-04-2019, 06:02 PM Thread Starter
IQRaceworks's Avatar
Question Vibration at 65-70mph? Ideas?
Even after new tires, wheels, getting them balanced, getting the driveshaft balanced with a new joints and carrier baring installed.....I still have a slight vibration I can feel in the seat at around 65-70mph. Under that it's smooth as can be....over that it's smooth as can be. Any ideas as to what could be causing it? Ordinarily I wouldn't care....but it's right at the speed that I cruise down the highway at...so it's annoying. It's a very high frequency vibration....not really like an out of balance tire. More like a driveshaft type vibration....but I've already had that balanced with all new u-joints.
Are these trucks just prone to some odd resonance type vibrations at difference speeds?
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
IQRaceworks is offline
post #2 of 4 (permalink) Old 02-05-2019, 01:16 PM
Weatherlite's Avatar
Garage
Re: Vibration at 65-70mph? Ideas?
Just about every Excursion and F-250 I've seen has a large harmonic weight attached to the transmission crossmember. Does yours have that? Other that than, I'd be looking at motor and tranny mount condition after all you went through to make sure things are balanced.
Another idea....find out the exact RPM when this vibration happens. Now, put it in a different gear and cruise at that RPM. Does it vibrate? If not, keep going up to 65-70 in that lower gear (assuming you're not using 1st lol). Does it vibrate at that speed and higher RPM? If it's RPM related, you may want to look at injectors causing a slight misfire or imbalance. Maybe a contribution test would be in order?
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 4 (permalink) Old 02-06-2019, 05:40 PM Thread Starter
I don't have a weight on my driveshaft.....and the shop the put the new joints in it and balanced it never mentioned anything about having a weight like that.
As far as what RPM is vibrates....it's speed dependent, not RPM/gear dependent. I can even drop it in neutral when running 75mph...and as soon as the truck slows to 65-70mph, you can feel the vibration...when it slows down under 65mph it goes away.
I'd say it definitely a driveshaft issue. Could slop in the slip yoke splines cause that kind of vibration?
post #4 of 4 (permalink) Old 02-07-2019, 01:52 PM
Garage
Sorry, I wasn't meaning a weight on the driveshaft, but hanging from the transmission/transfer case crossmember. Attaching a pic for reference. I know without those, sometimes a high pitch hum can come through the frame. I'll attach a pic.
If it's a high pitch vibration, it could be the splines. Has the slip yoke been well lubed/packed lately? That can cause some vibration. If you're sure it's not tires, and the shaft has been balanced, I would consider the yoke packing as one cause. Check for free play on the output shaft of the tranny/transfer case and on the pinion of the axle. If those bearings have up/down/side play it can cause vibration like that. Otherwise, maybe make sure your transmission mount is good, because if it has allowed your tranny to slip sideways too much, you could get a mis-alignment.
2004 Excursion 6.0
Similar Threads
2400 rpm at 70mph whichway 7.3L Power Stroke Technical Info 8 12-22-2012 06:09 PM
strange stumble at 60-70mph..TC? southmike 6.0L Power Stroke Technical Info 3 09-09-2011 05:44 AM
70mph white smoke farmboy93 1994-1997 Power Stroke Technical Info 16 08-11-2011 01:17 AM
random vibration speeds over 70mph Dangyo Suspension and Drivetrain 11 02-12-2011 09:27 PM
16-18 psi @ 70mph??? stroke of luck 6.0L Power Stroke Technical Info 26 02-03-2010 06:01 PM
