2004 350 60 truck stalling on me - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-25-2019, 12:11 AM Thread Starter
so just had the turbo veins cleaned, egr valve checked, replaced fuel pump and filters. two weeks later truck was having hard time starting and battery died boosted it and worked fine next day truck seemed to be running at lower rpm and sounded quieter, ran great but kept dying in park. in gear was good. next day needed jump again and now dies every time I put it in gear, it wont run in park unless I apply accelerator, take it off and it dies put it in gear and it dies. vip tested the battery and says good. any ideas? I can floor the pedal and seems to be lack of response and power
post #2 of 4 (permalink) Old 01-25-2019, 09:15 PM
Re: 2004 350 60 truck stalling on me
I've had batteries that they say tested goodand they were out of the truck. I got new batteries anyway and it was night and day difference to how the truck started. Maybe you should look into your alternator.
Johnny McG is offline
post #3 of 4 (permalink) Old 01-26-2019, 12:50 PM
CAT lover
Robertl211's Avatar
Sounds like a high pressure oil leak that started small and is now getting larger. You might consider an air check on the HPO system. Your HPOP could have gone.
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #4 of 4 (permalink) Old 01-26-2019, 08:52 PM Thread Starter
I just replaced batteries, no help. It does seem to get better once it warms up but issues is still there, code scan said crankshaft position sensor. regardless I took to the dealer and they will look at it Monday. Ill post the verdict.
