Need help on understanding the eot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 01-15-2019, 11:30 PM Thread Starter
Hey guys I’m new here and new to the diesel. So my 6.0 powerstroke EOT is getting up to 230 normal driving and my ECT is around average 170-190. I talked to the mechanic well thats what he call himself. He said he talked to a few others and they say that the oil cooler is good which I know that is not. Its not normal to have the degrees on those two that far apart. What do you guys think??
Jose6.0 is offline
post #2 of 16 (permalink) Old 01-15-2019, 11:36 PM
Re: Need help on understanding the eot
8-10 degree Delta is normal. Anything over 15 and you'd suspect the oil cooler, but additional work is required to test head gaskets as well.
I'd recommend taking it to a competent Diesel shop. Doesn't sound like you found one.
Sent from my Pixel 3 XL using Tapatalk
007matman is offline
post #3 of 16 (permalink) Old 01-15-2019, 11:40 PM
I found this on another site.. it'll show the proper test procedure from the TSB
post #4 of 16 (permalink) Old 01-15-2019, 11:42 PM Thread Starter
Can’t seem to see the image but if you have the link I can look it up and thank you for your help
Jose6.0 is offline
post #5 of 16 (permalink) Old 01-16-2019, 01:44 AM
matthewd11's Avatar
The oil cooler is definitely plugged. Do you still have the egr cooler in tact?
matthewd11 is offline
post #6 of 16 (permalink) Old 01-16-2019, 02:18 AM Thread Starter
ill have to check if it has been deleted or clogged up
Jose6.0 is offline
post #7 of 16 (permalink) Old 01-16-2019, 11:32 AM
matthewd11's Avatar
The egr cooler doesn’t clog. The oil cooler does, which then cuts off coolant flow to the egr cooler and then can rupture.
post #8 of 16 (permalink) Old 01-17-2019, 04:02 AM Thread Starter
Should I go ahead and replace both of them ? Just to be sure
Jose6.0 is offline
post #9 of 16 (permalink) Old 01-17-2019, 11:43 AM
"resident smarty pants"
What year model truck?
Overheating an EGR cooler can cause it to fail - especially if it is an 04.5 to 07 model year.
Mark
bismic1 is offline
post #10 of 16 (permalink) Old 01-17-2019, 03:24 PM Thread Starter
Its a 06 f250
Jose6.0 is offline
