Weird noise and pulling brakes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-15-2019, 01:25 AM Thread Starter
I have an 06 250. When applying the brakes it sometimes pulls. It’s random which way it pulls. When driving and not pressing brakes I can hear a groaning noise sounds like it’s coming from the booster area. Sometimes the brakes are stiff and sometimes normal. Also about 90% of the time when I turn right (about 3/4 of a turn) it makes the same groaning noise. Most of the time if I brake and turning right it will pull right. Has new calipers. Haven’t changed the brake lines, booster, master, or power steerjng pump. It also has a new vacuum pump. Any help is appreciated, I’m stumped.
Blue_06 is offline
post #2 of 6 (permalink) Old 01-15-2019, 12:52 PM
Weatherlite's Avatar
Garage
Re: Weird noise and pulling brakes
I'm thinking wheel hub bearings. You need to jack up the front end so there isn't any weight on the tires and grab that tire and try to move it up/down/left/right etc. I'd bet you have movement on one or both.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 6 (permalink) Old 01-16-2019, 01:10 AM Thread Starter
Doesn’t sound like a bearing but it’s worth checking out. Thank you!
Blue_06 is offline
post #4 of 6 (permalink) Old 01-17-2019, 03:17 AM Thread Starter
Should’ve mentioned the groaning noise isn’t all the time. It’s random and will happen for 1-3 seconds and stop
Blue_06 is offline
post #5 of 6 (permalink) Old 01-20-2019, 02:34 PM Thread Starter
Anyone?
Blue_06 is offline
post #6 of 6 (permalink) Old 02-17-2019, 12:37 AM Thread Starter
I replaced the booster and master cylinder today. It eliminated 99% of the pull. However the brake pedal will sometimes be hard than normal. It’s mostly when I’m turning right. I’m lost at this point. The steering isn’t stiff so I don’t think it’s the pump. If someone has a suggestion let me know!
Blue_06 is offline
