Turbo whistle louder than normal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-14-2019, 05:49 PM Thread Starter
Kshellum's Avatar
Got an 05 6.0L and I usually push about 20-23# of boost when getting on it. But lately I've been pushing about 30-35# and after about 20# my turbo whistles louder.(no I dont sit and ride it over 20#) I did have a cracked intercooler boot, replaced but still doing it. I'd assume it's an air leak, just not sure where to look?
Kshellum is offline
post #2 of 10 (permalink) Old 01-14-2019, 05:50 PM Thread Starter
Kshellum's Avatar
Re: Turbo whistle louder than normal?
It's a high pitched whistle, I wouldnt think it's my wheel going bad?
Kshellum is offline
post #3 of 10 (permalink) Old 01-15-2019, 12:48 PM
Weatherlite's Avatar
Garage
I've heard cracked up-pipe bellows whistle quite loud.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #4 of 10 (permalink) Old 01-15-2019, 05:49 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
yeah, those whistling pinholes in the uppipe bellows are annoying lol
so it's hitting over 30 psi without an overboost code?
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #5 of 10 (permalink) Old 01-16-2019, 01:56 AM
Scherf's Avatar
Garage
Wonder if the vgt is stuck closed around the hot wheel over speeding it too
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #6 of 10 (permalink) Old 01-16-2019, 01:57 AM
Scherf's Avatar
Garage
Ya but wouldn’t cause boost to build though
Scherf is offline
post #7 of 10 (permalink) Old 01-16-2019, 05:26 PM
IQRaceworks's Avatar
I would put money on the VGT being stuck/sticky/bound up.
You shouldn't ever be getting 35psi of boost......sounds high. I think "normal" is 25-29 when under load.....less when not loaded.
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
IQRaceworks is offline
post #8 of 10 (permalink) Old 01-16-2019, 08:18 PM
79jasper's Avatar
Before saying the boost is "high," let's ask @Kshellum if he has any tuning?.......
79jasper is offline
post #9 of 10 (permalink) Old 01-20-2019, 12:01 AM
Well....he said that he "normally pushed 20-23psi of boost".....that's low with a tune, or without one. As far as the 35psi of boost he's getting now...are there any tunes out there that will bump it up that high? I have several IDP tunes.....(towing, street, extreme), and none put out more than 29psi of boost under load. 35psi sounds like a bunch.
post #10 of 10 (permalink) Old 01-20-2019, 12:37 AM
79jasper's Avatar
I guess it could be. I was doing 40 before replacing Injectors, with a fooler.
79jasper is offline
