Coolant Drip - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By heavydoc
post #1 of 7 (permalink) Old 01-09-2019, 11:13 PM Thread Starter
lomac's Avatar
Coolant Drip
The last week or so I've noticed a small coolant drip/smell. It's hitting the center support of the dual steering stabilizer and may be a golf ball to tennis ball size amount on the ground in the morning. Don't notice it while idling, mostly after sitting a bit. The truck in Not overheating. Water pump? Thanks in advance for any advice
lomac is offline
post #2 of 7 (permalink) Old 01-09-2019, 11:39 PM
PSN intsigator
heavydoc's Avatar
Re: Coolant Drip
Could be a loose clamp also
Sent from my super awesome outdated Samsung phone while waiting for masakimms# 500mA overdraw draw to catch fire which turd will be blamed for and we will be sitting on dustybumpers tailgate watching the fire and plotting against yommy.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 7 (permalink) Old 01-10-2019, 12:47 AM Thread Starter
lomac's Avatar
Re: Coolant Drip
I've looked all around the clamps and everything is tight and dry. Can't see much from the bottom.
Guess I'll have to pull everything to get a visual as to whats going on.
lomac is offline
post #4 of 7 (permalink) Old 01-10-2019, 12:51 AM
PSN intsigator
heavydoc's Avatar
Re: Coolant Drip
Try a mirror
lomac likes this.
heavydoc is offline
post #5 of 7 (permalink) Old 01-10-2019, 01:08 AM
Moderator
Sbluke55's Avatar
Re: Coolant Drip
Sounds like the water pump. But I would look at the weep hole on the bottom of the pump first.
01 f-250, Standard
Sbluke55 is offline
post #6 of 7 (permalink) Old 01-10-2019, 03:44 PM
Re: Coolant Drip
I had a similar leak and replaced the water pump. It ended up being the doughnut between the intake and the block. Truck was leaning slightly to the drivers side and slightly downhill when parked and it would run down that side in the front.
My first vote is water pump. If that wasn't it then I would check that doughnut or something else up on the intake.
Turbospin is offline
post #7 of 7 (permalink) Old 01-16-2019, 05:30 PM
IQRaceworks's Avatar
Re: Coolant Drip
Do you have a coolant filter on the truck? I has a small leak right behind the alternator where the plastic T tied into the coolant lines. Took me a while to find it...it was hidden pretty good.
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
IQRaceworks is offline
