Problem with 6.7 pump after filter change - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-05-2019, 09:24 PM Thread Starter
jrex2506's Avatar
So ordered all new fuel filters to install. I am running 1/2" lines from sump to napa 3528 filter, then to my 6.7 pump then to a regulated return. After changing both filters i didnt get the housing tight enough, so it sucked air and truck shut off. Long story short it will not pump fuel now. I hear the pump turn on and run, but no fuel. Could i have screwed the pump up? I know its a rookie mistake, didnt realize to tighten the housing to the stops. I was pretty snug with it tho, didnt require more than one turn.
Sent from my SM-S727VL using Tapatalk
2001 Ford 7.3 6" lift, ts chip, custom bumper and rack. intake,
Wife's 2005 F250, 6.0 crew cab short bed with 6 speed! studs and all the other goodies to bulletproof it.
jrex2506 is offline
post #2 of 3 (permalink) Old 01-08-2019, 02:23 PM
Weatherlite's Avatar
Garage
Re: Problem with 6.7 pump after filter change
Wrong section...you're in the 6.0
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 3 (permalink) Old 01-09-2019, 12:33 AM
sooty
It probably has air lock. You need to bleed it somehow.
You would know how to best as your setup isnt factory
sooty is offline
