6.0 pin in the low pressure oil pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Cummins Junkie
post #1 of 8 (permalink) Old 01-05-2019, 08:27 PM Thread Starter
My neighbor has a 2007 6.0 550. He bought it in a no start condition I believe. He found a pin in the lpop and when he removed it it started and ran fine. He didnít investigate where the pin came from I donít guess.... now after driving it for some time it wonít run again. Hereís a pic of what he found. Any idea where he should go next?
nsfr1206 is offline
post #2 of 8 (permalink) Old 01-05-2019, 10:04 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 6.0 pin in the low pressure oil pump
That is a needle bearing. The hydraulic lifters have those in them.
Scherf likes this.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 8 (permalink) Old 01-05-2019, 10:04 PM Thread Starter
Uhoh
nsfr1206 is offline
post #4 of 8 (permalink) Old 01-05-2019, 10:06 PM Thread Starter
He did tell me he was trying to start and heard a crunch. That tells me he probably has a big problem now.
nsfr1206 is offline
post #5 of 8 (permalink) Old 01-05-2019, 10:15 PM
Garage
Yea those lifters are coming apart, likely spreading metal debris throughout the engine. That crunch was probably the lpop eating another bearing.
post #6 of 8 (permalink) Old 01-05-2019, 10:16 PM Thread Starter
He has a lift and has had cab off before. Thatís his plan again. Iíll tell him where that pin likely came from and we will go from there. Thanks.
nsfr1206 is offline
post #7 of 8 (permalink) Old 01-05-2019, 11:41 PM
"resident smarty pants"
This is why I have some strong magnets on the bottom of the oil pan! That "might" (emphasis on might) help keep these roller bearings from being sent forward.
The LPOP cover is already off, have the the LPOP gears been removed? Front cover removed? Most likely all will need to be replaced, along w/ the lifter work that will need to be done. Run your fingernail over the cover surfaces to feel for scratching. It doesn't take much to cause issues w/ the LPOP developing pressure.
Check the oil filter and drain the oil - look for any signs of metal.
Please keep this thread going because it will get interesting when you find out which lifter(s) are bad and if you decide to remove the engine to replace them all (or worse).
Mark
bismic1 is offline
post #8 of 8 (permalink) Old 01-05-2019, 11:56 PM Thread Starter
Ok. Iíll try to keep it updated when he gets to it. Heís currently taking a V10 out of his 250 and putting in another engine. So itíll be a bit.
nsfr1206 is offline
