Hard start, surges, runs rough when cold. FICM or injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 8Likes
post #1 of 36 (permalink) Old 12-31-2018, 02:14 AM Thread Starter
Question Hard start, surges, runs rough when cold. FICM or injectors?
Guys:
I'm at a little bit of a crossroads here...
2005 Excursion with 230K miles on the clock. New batteries, good charging system and ALWAYS see 47.5V to 48.5V FICM power on the SCT live wire.
When it is cold, usually a longer crank than normal and runs rough, until driven about three miles. Also see hard start on warm starts. Feel some surging at light throttle application. Hot starts are OK.
I did the injector test on IDS and when it was ice cold, I will only hear two injectors fire. Another time I did the test ice cold, I heard 6 fire. If the test is repeated when hot, all 8 fire.
The question is, can I have six bad injectors, or could the FICM be responsible, even though FICM power is rock solid around 48V?
Best Regards,
Steve
Houston, TX
skent is offline
post #2 of 36 (permalink) Old 12-31-2018, 02:32 AM
207RIDER's Avatar
Re: Hard start, surges, runs rough when cold. FICM or injectors?
I would think it's likely a stiction issues with the injectors on cold start ups. sometimes a treatment like revx can help with an oil change. fresh oil change and fuel filters with an additive in both would be my first step.
Sent from my Moto Z (2) using Tapatalk
207RIDER is offline
post #3 of 36 (permalink) Old 12-31-2018, 02:48 AM
Mine ran rough either hot or cold. I had issues before with one bad injector as it got colder i was only running on 5 cylinders and 4 injectors were bad went ahead and replaced all 8 and havenít had any issues since then. I would say replace all injectors and call it a day.
rays06strokin is offline
post #4 of 36 (permalink) Old 12-31-2018, 03:38 AM Thread Starter
Thanks for the reply.
About a week ago, oil was changed and today I did both fuel filters. Tried to find RevX at the local parts houses and no cigar. I did shoot a quart of the Power Service Diesel injector cleaner into the tank today, for whatever that's worth.
Regards,
Steve
skent is offline
post #5 of 36 (permalink) Old 12-31-2018, 12:49 PM
"resident smarty pants"
It would be good to listen closely and count when you are doing the injector testing. They are tested in numerical order (1-8) so you should make a mental note of which two don't have the proper sound during the test.
Mark
bismic1 is offline
post #6 of 36 (permalink) Old 12-31-2018, 12:50 PM
Regards,
Steve
Injector cleaner is for the fuel side. IMO it is a waste of money. Stiction treatment is for the oil side. IMO you need an oil side treatment, like 207RIDER mentioned, or new injectors.
So, what oil are you using? Did you just add a 15W40 oil for your oil change?
Mark
bismic1 is offline
post #7 of 36 (permalink) Old 12-31-2018, 12:58 PM
207RIDER's Avatar
yes like I mentioned earlier in the post you can try the Rev x treatment or another substitute it may work as others including myself had great luck with it before, I had similar stiction issues and after a few fresh oil changes with rotella t6 5w40 and the Rev x treatment and it did work out about 90% of the issues however it's generally a bandage for a bigger problem which could be injectors
207RIDER is offline
post #8 of 36 (permalink) Old 12-31-2018, 04:06 PM Thread Starter
I am using Delo 5W40 full synthetic. Have been running it for 2.5 years. Are any of the oil side treatment products available at the big parts houses or are they online order only?
Best Regards,
Steve
skent is offline
post #9 of 36 (permalink) Old 12-31-2018, 04:12 PM Thread Starter
Yup. The one thing that is consistent is that whenever the test is performed and it is cold, #6 never fires.
I see the same deficiency when running the cylinder contribution test when it is cold. When it is surging, #6 is down.
Best Regards,
Steve
skent is offline
post #10 of 36 (permalink) Old 12-31-2018, 04:13 PM Thread Starter
I will go and run the injector test now since it is cold and report back....
Best Regards,
Steve
skent is offline
