P2287 on new rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-30-2018, 02:57 PM Thread Starter
Theoilbarn's Avatar
This code occurred after the first hour of idle time. New sensors all around and new harnesses. Runs rough from idle to 1000rpm then clears up. Icp is reading 600s at idle and 800s at 1000rpm. And the ipr is at 25% to 30%. My injector pulse width is .90-1.09. ficm 48-48.5v. and 13v going into the ficm. I did delete code once but came back 10mins later of idle time.
Theoilbarn is offline
post #2 of 7 (permalink) Old 12-30-2018, 05:11 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: P2287 on new rebuild
Did you replace the ICP sensor? Is the wiring on the pigtail all bent up? Also, you're not letting a brand new engine idle for an hour are you?
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 7 (permalink) Old 12-30-2018, 05:50 PM Thread Starter
Theoilbarn's Avatar
Yes . Pigtail is good. and no. Running at different rpm's
post #4 of 7 (permalink) Old 12-31-2018, 01:08 PM
"resident smarty pants"
OEM ICP sensor?
Mark
bismic1 is offline
post #5 of 7 (permalink) Old 12-31-2018, 06:16 PM Thread Starter
Theoilbarn's Avatar
No gb remanufacturing for both icp and ipr. Always use this brand on the 7.3l I had for all my sensors and never had any issues.
post #6 of 7 (permalink) Old 12-31-2018, 06:29 PM
I am not a fan of aftermarket sensors and actuators. Have seen way too many problems arise from using them.
Mark
bismic1 is offline
post #7 of 7 (permalink) Old 12-31-2018, 07:18 PM Thread Starter
Theoilbarn's Avatar
I ended up putting in the old icp and it runs good now. Will keep updating if this code keeps coming up
