6.0 dies when driving - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-21-2018, 01:27 AM Thread Starter
i have a 6.o when driving it loses power then dies. will idle fine for hrs. all pids look good but when it goes to losing power the load pid goes from 60% or less to 99%. when load goes up is when the the truck loses power and dies. has any one had this issue that could help me?
cfleming5 is offline
post #2 of 4 (permalink) Old 12-21-2018, 04:54 PM
Re: 6.0 dies when driving
What does the exhaust look like? What's the ICP and what's the fuel pressure?
post #3 of 4 (permalink) Old 12-21-2018, 09:48 PM
Scherf's Avatar
Garage
Man I have been dealing with this on a 7.3 for the past day, and today I discovered the injectors and harness is the cause..... this is due to heat and wear in them.... only would do this after a bout an hour of running. But also look at the icp pressure. If itís trying to maintain it, I would then start looking at your harness for your Injectors or the injectors itself..... too bad you cannot do a buzz test after it dies like I did to find this issue
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #4 of 4 (permalink) Old 12-22-2018, 01:16 AM Thread Starter
the exhaust is clean no crazy smoking or change when it starts to die. icp pres is all norm and ill have to go back and look at fuel press. it does not have any throttle response when its going to die. have replaced fuel pump and ficm and two injectors. due to cylinder contribution test codes on number 1 and 5
