06 Turbo Whine? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-18-2018, 02:59 PM Thread Starter
Anitopi11x's Avatar
06 Turbo Whine?
Not sure if this is the right spot to post this or not. Truck is a fully deleted studded 06 with 99k miles on it. Religiously maintained never skimp on service. Noticed today on my way to work my turbo seemed to be working harder than usual (higher than usual psi) under normal load. When letting off the throttle you can hear a slight howl noise right before the "fart"! Never had this noise happen before. Any ideas would be much appreciated. Also VGT on SCT x4 seemed to be okay and moving.
2006 F-350 CC Lariat Short Bed
XDP EGR Delete
XDP Coolant Filter Kit
Banks Monster Dual's Straight Piped
Banks Ram Air CAI
Blue Spring Update
SCT X4 With Innovative & Looney Tunes
ARP Studded
BPD 48v FICM
6" Skyjacker Lift
35x12.50's on 20's
Anitopi11x is offline
post #2 of 3 (permalink) Old 12-18-2018, 05:03 PM
Jackleg Mechanic
mastrkee's Avatar
Re: 06 Turbo Whine?
Id start with removing and cleaning the ebp sensor and tube. I had a similar problem with my 06 and this helped a great deal. I eventually had to pull the turbo and clean the vanes and unison ring.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 3 (permalink) Old 01-03-2019, 11:25 AM Thread Starter
Anitopi11x's Avatar
Re: 06 Turbo Whine?
@mastrkee that's exactly what it was. Realized it right after I posted this and got in my truck!
XDP EGR Delete
Banks Ram Air CAI
Blue Spring Update
ARP Studded
BPD 48v FICM
6" Skyjacker Lift
35x12.50's on 20's
