No start after head job - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 12-17-2018, 03:20 PM Thread Starter
Scherf's Avatar
Garage
Sooo this one stumps me dearly....
Head gaskets replaced
03 model
Ipr 56% with icp pressure @ 1790
Crank and ficm sync
Cranking was 160rpm (batteries were dying, on a charger till I try cranking again)
Fuel in the heads (cracked a line to make sure)
New FORD injectors
Newish ficm (replaced before heads)
Ficm 58v @13.5v going in and 13.5v logic
New oil cap and filter with fluid change....
So what the hell is the issue here?!?!?!
No codes and I know crank speed was low when I got the numbers
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #2 of 19 (permalink) Old 12-17-2018, 03:28 PM Thread Starter
Scherf's Avatar
Garage
Re: No start after head job
Update, 6.4 starter being brought to me now, toasted the current one
Scherf is offline
post #3 of 19 (permalink) Old 12-17-2018, 03:45 PM
matthewd11's Avatar
Do you hear the injectors cycle when you turn the key on? I would make sure all the ficm connectors are clipped in on both sides.
matthewd11 is offline
post #4 of 19 (permalink) Old 12-17-2018, 05:16 PM Thread Starter
Scherf's Avatar
Garage
Yes my friend, checked them when I checked the ficm
Scherf is offline
post #5 of 19 (permalink) Old 12-17-2018, 05:27 PM
79jasper's Avatar
I would be looking into compression. Especially since you just had the heads off. Too many possibilities. Glowplugs left out? Valve issues?
79jasper is online now
post #6 of 19 (permalink) Old 12-17-2018, 06:01 PM
Master BS'er
jamiesaun's Avatar
I've seen these things take forever to start before. It's only happened a few times, but I have seen it. Like over half a day sometimes.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #7 of 19 (permalink) Old 12-17-2018, 08:05 PM Thread Starter
Scherf's Avatar
Garage
No, I wouldnít say so, head off to the machine shop and came back good, lifters compresses when Rods were pushed on.... I havenít checked compression but we did just get the new starter on
Scherf is offline
post #8 of 19 (permalink) Old 12-17-2018, 09:21 PM Thread Starter
Scherf's Avatar
Garage
Got the starter on and still nothing, havenít compression tested but the fuel bowl is making a hellish noise. Sounds like the regulator may not be working correctly and allowing fuel to bypass and not allow pressure to build correctly.
Gonna address that in the morning
Scherf is offline
post #9 of 19 (permalink) Old 12-18-2018, 03:11 AM
I know both times I've had the HPO system apart I've had to crank for an ungodly amount of time to bleed air out of the HPO system.
Definitely check the fuel pressure. Gotta establish that is good.
Good luck!
post #10 of 19 (permalink) Old 12-18-2018, 11:30 AM
matthewd11's Avatar
Does the ICP read zero with Koeo? I know youbsaid you have stranger noises from fuel bowl definitely investigate that just trying to cover all bases. Is there smoke out the tailpipe when cranking?
