04 6.0 low boost in 1st gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-16-2018, 12:43 PM Thread Starter
I have a bone stock 04 6.0 with a 6 speed stick. The truck runs great but produces very little boost until 2nd gear. The DashBoss recorded about 8lbs at 3100 rpm just before my shift to 2nd. 2nd - 5th it cranks out 21-23lbs. No codes. Any suggestions?
Fatpat42 is offline
post #2 of 6 (permalink) Old 12-16-2018, 01:53 PM
matthewd11's Avatar
There isn’t enough load on the engine in first gear to create that much boost.
matthewd11 is offline
post #3 of 6 (permalink) Old 12-16-2018, 04:40 PM Thread Starter
So you would consider 8-10 lbs of boost normal for first gear? I’m talking 1st not L just to be clear. Even off the line with WOT?
Fatpat42 is offline
post #4 of 6 (permalink) Old 12-17-2018, 12:47 PM
Weatherlite's Avatar
Garage
Re: 04 6.0 low boost in 1st gear
Agreed. You would need more load/more time to develop more boost in first. If you had a heavy trailer attached you would see different results.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #5 of 6 (permalink) Old 12-17-2018, 03:14 PM
matthewd11's Avatar
Hook a trailer with good weight on it and you’ll see more boost.
post #6 of 6 (permalink) Old 12-19-2018, 02:30 PM
my 03 truck has for awhile been gutless in first gear (mine is an auto) accelerated ok in second. when it was new it had plenty enough power to spin the tires. I was ok with this as long as it performed at hwy speeds which it did until earlier this year. While I was tinkering about trying to eliminate potential boost issues I fixed the sluggish 1st gear issues when I put new o-rings on my EGR valve. My truck had been down recently an it was already cleaned and the o-rings looked ok but new ones helped. Only a $10 fix. worth a try?
knotreel is offline
