2006 DRW 4wd rear caliper mulitple failures. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-22-2018, 01:36 PM Thread Starter
06F350Dually's Avatar
I’m new here. I have an 06 F350 XLT Crew Cab. It only has 142k on it and it runs like a top. Its completely stock except I deleted the EGR and have a sct tuner that is used to clear the code for the delete. I lost my brakes 2 months ago. The pass side rear caliper failed. Loss of fluid etc. I ended up replacing both rear calipers, and pads. Well it happened again. I’ve searched for a common issue but can’t find any. Am I missing anything? Any help is appreciated. If missed a previous post my apologies and if so please point me in the right direction.
Thanks
06F350Dually is offline
post #2 of 3 (permalink) Old 11-22-2018, 06:32 PM
matthewd11's Avatar
What brand calipers did you replace them with? Did you replace the pads and rotors too?
matthewd11 is offline
post #3 of 3 (permalink) Old 11-22-2018, 08:54 PM
don't play well w others
Dustybumpers's Avatar
Re: 2006 DRW 4wd rear caliper mulitple failures.
Did you replace the rubber lines to the calipers?
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
