2005 6.0 leaking coolant? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-19-2018, 10:45 PM Thread Starter
JSams's Avatar
I'm very novice with engines so sorry in advance for my lack of terminology. Came home today and noticed the truck had been leaking something. Feels slightly slick and greasy like oil (not as thick) but smells more like coolant. Fairly clear in color. Looks to be coming off some smaller lines of some kind near the undercarriage of the truck under the passenger side? Any help is appreciated
JSams is offline
post #2 of 5 (permalink) Old 11-20-2018, 10:40 AM
"resident smarty pants"
Re: 2005 6.0 leaking coolant?
When it comes to leaks, help over the Internet is hard to give.
It could be radiator hoses, hose under the degas bottle, thermostat seal, radiator itself, over-pressuring of the degas bottle, leaking degas bottle (cap or plastic bottle), etc.
You just have to clean up all you see and watch for it to begin again. Catch it early before it spreads.
You can also rig up a hose from a small air compressor and "tee" it into a vent hose that goes to the degas bottle and pressurize the coolant system (go to 15 psig max). Then look for an active leak.
Mark
bismic1 is offline
post #3 of 5 (permalink) Old 11-20-2018, 01:18 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
sub'd!
Is it dripping onto the ground? If so, catch some of the drippings in a clean milk jug cut in half, or something similar, and then post a picture of it for us! :p
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #4 of 5 (permalink) Old 12-01-2018, 07:56 AM
I thought generally if its on the passenger side its EGR related?
Jack3d_Dually is offline
post #5 of 5 (permalink) Old 12-01-2018, 11:25 AM
Turd-250's Avatar
Could be heater hoses on passenger side as well
Turd-250 is offline
