03 6.0 truck stalled..crank no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-19-2018, 01:12 AM Thread Starter
Well "Nation" back at it again after a year almost to the day. Another hpop, 2nd reman aftermarket!! First aftermarket went almost 1 1/2 yrs. 2nd went almost a 1 yr. Motorcraft reman this time Auto Value the 1st time . And another new icp sensor both which were Ford parts. And 8 Bosch injectors. I find myself driving down the road and truck stalls....😠 a crank no start issues lurks back again. The only thing that has been different is I noticed the gauge cluster is fritzing ocassionally. So other than my fit of rage on this truck, I had it towed and has been sitting in the barn. With frustration over ruling my need to somewhat diagnose this hunk of 💩 6.0. I wanted to ask if the gauge cluster fritzing would have any issue with the truck stalling and a crank no start issue emerging. Thanks again for the amount of knowledge on this forum.
ATGF79 is offline
post #2 of 6 (permalink) Old 11-19-2018, 02:16 AM
"resident smarty pants"
Re: 03 6.0 truck stalled..crank no start
The instrument cluster could be responsible for a crank no-start.
Pull codes with a quality code reader and try to monitor the vreference voltage when cranking.
So will low battery voltage.
I am not a big fan of OEM HPOP's. The only ones I would consider would be the Adrenaline pump and the upgraded one from CNCFab.
Mark
bismic1 is offline
post #3 of 6 (permalink) Old 12-04-2018, 01:26 AM Thread Starter
Thanks..I will put it in my memory bank for when I talk to the Ford tech in the morning for some Q&A they have the truck.
ATGF79 is offline
post #4 of 6 (permalink) Old 12-04-2018, 02:30 AM
Let me qualify an earlier post - I am not a big fan of the 03 and 04 HPOP's. The 05 and up OEM HPOPs are reliable pumps.
Mark
bismic1 is offline
post #5 of 6 (permalink) Old 12-05-2018, 08:05 PM Thread Starter
Obviously without photos at the moment. What is this truck worth? I can't afford these trucks. My diesel knowledge is dangerous to say the least. It's an 03 f 250 crewcab 4x4 xlt. It is bone stock except for the egr delete that was done to it a while back. Just had new hpop (motorcraft)all the gaskets and seals, (motorcraft)from the removal and the replacement of the intake to replace hpop and I believe it's called injection pipe coming from the hpop? New icp and harness, ipr. truck has 189 k on it. It has the typical Ford from southern lower Michigan rust.
ATGF79 is offline
post #6 of 6 (permalink) Old 12-05-2018, 10:54 PM
CAT lover
Robertl211's Avatar
3500-5500 by me with the same miles and rust
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
