Death wobble banging and screaching - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-12-2018, 11:00 PM Thread Starter
In the pic I have uploaded can anyone tel me what would cause those 2 lives to be touching, on the driver side ther is about a 1/4 inch of space between them. And at times the parts that are touching actually go back to having space. Is that a wheel hub issue? This is my first super duty. It’s a 05 f350 crew cab long bed 4wd and that dang 6.0.
File Type: jpeg 4C6DB915-AB2D-4F93-9124-CC391198B2FF_1542067094753.jpeg (176.0 KB, 84 views)
Dslover927 is offline
post #2 of 5 (permalink) Old 11-13-2018, 12:15 AM
79jasper's Avatar
Re: Death wobble banging and screaching
The actual name is slipping my mind. Spindle bearing? I dont know if it's replaceable on the unit bearing trucks.
79jasper is offline
post #3 of 5 (permalink) Old 11-13-2018, 02:17 PM
matthewd11's Avatar
The axle support bearing inside the hub unit is sold separate if that’s what you need
matthewd11 is offline
post #4 of 5 (permalink) Old 11-13-2018, 06:25 PM
Administrator
Zmann's Avatar
the 05 up axle support bearing is a sealed bearing and way more reliable than the 04 under needle bearing but
like mentioned they can be replaced separately from the actual unit bearing
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 5 (permalink) Old 12-13-2018, 11:02 PM Thread Starter
Man it ended up being my wheel hub. The whole thing was just destroyed. Had to replace that from part of the axle as well because it was shaving down while I was driving it. It mustve been bad for awhile, but I never heard any of the usual noises I’ve heard when hubs have gone bad. She’s all good now. Now that I’m thinking of it I probably should’ve put the leveling kit on while I had the front end apart
