6.0 oh no! Update - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-08-2018, 12:36 PM Thread Starter
Tigwelder76's Avatar
6.0 oh no! Update
So, it turned out to be my IPR valve was bad. It's now fixed and running! On the other hand. I found that my Y pipe is cracked and I have 3 dead glow plugs. My saga continues. Lol
Tigwelder76 is offline
post #2 of 3 (permalink) Old 11-09-2018, 11:42 AM
Scherf's Avatar
Garage
Re: 6.0 oh no! Update
food for thought on the Y pipes, i am going to be installing a three or 4 piece y pipe today by BD. looks like it will make the job easier then a standard y pipe. ill let you know how it goes. (install will be with cab on, turbo removed FYI)
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #3 of 3 (permalink) Old 11-11-2018, 03:44 PM Thread Starter
That would appreciated. I knew I had an exhaust leak. But I thought something didn't seal up right from when I replaced my hpop. The flex joint on my ypipe probably cracked during that whole process.
