6.0 towing problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-05-2018, 11:01 PM Thread Starter
6.0 towing problem
I have a buddy looking to buy a 6.0 that he willl use for work. Truck seems to run fine and build boost when he is not towing anything but the second he put a trailer on the truck becomes gutless and can barley get it to 55 mph in to mode. Anyone have this kinda problem? Truck has some mods done to it coolant filter supposedly been bulletproof
6nopowerstroke is offline
post #2 of 7 (permalink) Old 11-05-2018, 11:14 PM
Woody6.0to7.3's Avatar
what year is the truck it can help us figure out issues by year , also every diesel owner especially a 6.o owner knows that with a corrrect monitor you can point out issue like low boost due to y pipe leak or a simple as a damaged cac tubes
Woody6.0to7.3 is offline
post #3 of 7 (permalink) Old 11-05-2018, 11:17 PM
I purchased a 04 dually 3 years ago that had a cracked y pipe on driver side bellow which was hissing like a mother ####er lol and when i stomped on it it took for ever to take off ,im leaning to that bud .im.sure guys here will chime in to help , but then again i sold it and went to a 2000 7.3 lol
post #4 of 7 (permalink) Old 11-05-2018, 11:23 PM Thread Starter
what year is the truck it can help us figure out issues by year , also every diesel owner especially a 6.o owner knows that with a corrrect monitor you can point out issue like low boost due to y pipe leak or a simple as a damaged cac tubes.
It’s a 2006 f250. I have the same truck but a 350 and have pulled plenty of trailers with no problem so I’m not much help for my buddy other than having him look at a few basic things. Sounds like a ypipe sometimes causes this problem.
post #5 of 7 (permalink) Old 11-06-2018, 12:08 AM
Tell him to look at the driver side black plastic cac tube going into the intake manifold infront of the egr valve, it has known to crack on the bottem , also hear around for leaks it can be causing him low boost those y pipes love to crack over time, also make sure the maf- mass air flow is connected correctly to the air intake maybe dirty or damged even the epb sensor... have it scanned to see if it has any codes stored. I just purchased a obII bluetooth 23 bucks from amazone took 3 days to get and forscan and torque pro for 5bucks on android or iphone each and it saved me from taking my rig to guys who charge 65 or more to scan our trucks . 6.0s are laggy down on start but once the vgt turbo lets loose she becomes a beast but they are very bery delicate beasts and loved to be maintained like crazy .
post #6 of 7 (permalink) Old 11-06-2018, 10:23 PM
Scherf's Avatar
Garage
Re: 6.0 towing problem
Depending on the miles, I would also think of maybe cleaning the vgt side of the turbo
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #7 of 7 (permalink) Old 11-12-2018, 12:22 PM
Weatherlite's Avatar
Garage
There are far too many possibilities. We could probably through out a dozen and there would still be a couple dozen other possibilities. Your friend is going to need to give you some specs so you can share with us. Stuff like ICP, IPR, boost, injector pulse width, EBP, ECT, EOT, FICM input and output, and I would even take a look at CFM through the air inlet tube. Sure, if it's just a CAC tube leak, you'll only need one of those readings....or if it's a dropped injector you'll probably only see it in codes...but figuring it out will be a lot easier with all of the information. Oh, and I would have him collect that info at idle, at speed unloaded, at speed loaded, and perhaps even during acceleration while loaded.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
