6.0 engine cut off put out codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-28-2018, 10:26 PM Thread Starter
P2138 p2140 i was drving going over speed but and it died check engine light came on i restarted it it came on and cut off did it one more time pushed a throttle a bit and it stayed running. On my way home ran ok i checks codes while driveing and the 2 codes showed up . there was on big hard surge felt like i tossed it to reverse but not sure. Got home checked codes and nothing showed up let is sit for a while i cranked it and let it idle..... a few times i lt wanted to die or back fire not sure rechecked codes and both of the show along woth p2285
So i have p2189 p2140 and p2285 any help or advise on what i should start with thank you
A.ortega49 is offline
post #2 of 4 (permalink) Old 10-28-2018, 11:20 PM
"resident smarty pants"
Re: 6.0 engine cut off put out codes
P2189 isn't a diesel code
P2138 and P2140 are throttle position codes: Correlation between the triple redundant sensors (D/E and E/F). You might need a new pedal.
P2285 is an ICP code: ICP Sensor - Circuit Low. Visually inspect the ICP sensor harness and connector for damage, corrosion, or incorrect routing. This is what you get when you disconnect the ICP.
The P2285 can cause a no-start or cause the engine to die.
Mark
bismic1 is offline
post #3 of 4 (permalink) Old 10-29-2018, 12:55 AM Thread Starter
Sorry fat fingers it was p2138 not 89
But the issue is intermitten the truck runs fine now anything i should look at or just change parts?
post #4 of 4 (permalink) Old 10-29-2018, 01:04 AM
I don't believe you can get sensors individually, you have to buy the entire pedal assembly.
It could be wiring as much as it is the pedal. It is a critical component, that is why the sensors are triple redundant. I would want to resolve the issue, but the triple redundancy exists for reliability and safety and is enabling you to still drive it.
Mark
bismic1 is offline
