need a little help - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By bismic1
post #1 of 6 (permalink) Old 10-26-2018, 11:09 PM Thread Starter
need a little help
2003 f250 6.0
hard to start and runs rough unless i unhook the #7 injector.
then it will start right up and idle.
so i swapped #3 and # 7 injectors to see if i had a faulty injector.
nope still have to unplug #7 to get to run.
while it is running and u try to connect #7 back up it will stutter and die.
so i had it running and unhooked #5 and put #7 connector on 5 and it died.
so i took the injector harness off and ohmed it out and no shorts.
FMP is 48
any ideas????
jerryridge is offline
post #2 of 6 (permalink) Old 10-26-2018, 11:30 PM
"resident smarty pants"
Re: need a little help
FICM power board (source for 48V) isn't the only area of potential failure of a FICM.
Can you try (borrow) a known good FICM?
Mark
bismic1 is offline
post #3 of 6 (permalink) Old 10-26-2018, 11:35 PM Thread Starter
my buddy has one in a 04. i assume it would be the same?
post #4 of 6 (permalink) Old 10-27-2018, 12:32 AM
It would work fine.
jerryridge likes this.
Mark
bismic1 is offline
post #5 of 6 (permalink) Old 10-27-2018, 07:02 PM Thread Starter
ended up being the ficm. swapped it with a good one and truck started and runs good.
post #6 of 6 (permalink) Old 10-27-2018, 07:07 PM
Good deal. Glad to help. Appreciate the "like".
Mark
bismic1 is offline
