Bulletproof Diesel head crack repair kit? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 07-17-2016, 11:09 PM Thread Starter
Gaius's Avatar
Anyone use this to repair a crack in the injector bore? I have a crack above the cup on #5.
It's about half the price of a head, but I don't have the ability to lift the cab to do a proper head job. This kit looks promising.
Anyone have experience with it?
BPD Cylinder Head Repair Tool, Ford 6.0L
BTW, here is my diagnosis:
2005 F350 6.0/5r110
1998 Jeep TJ 5.9/46RE/Stak D300
Gaius is offline
post #2 of 18 (permalink) Old 07-18-2016, 04:22 AM
Weatherlite's Avatar
Garage
Re: Bulletproof Diesel head crack repair kit?
Never used it. Don't know anyone who has. If you have the money, you can do a head job with the cab on....just takes a little patience and finesse.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 18 (permalink) Old 07-19-2016, 01:37 AM
codykthekilla's Avatar
Garage
There is a new product out there, 6.0L Ford Powerstroke Cylinder Head Repair Kit - Save $5,000! , it replaces the cup with a longer one and you have to change the base of the injector.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #4 of 18 (permalink) Old 07-19-2016, 03:26 AM Thread Starter
Gaius's Avatar
Thanks for the recommendation. Was hoping I could find someone who has put some miles on Bulletproof's fix before.
This morning I called and talked to Tim at Accurate Diesel, and decided to go with their kit. I'm not too excited to have a different lower injector body, but only because it offends my OCD. :)
I'm only 90% sure it's the head, it still may be the cup. I can't quite get in there with my eyes, only with a mirror. So after spending the $650 on the BP tool, I still may need to buy/rent a cup puller and do the cup. With the Accurate Diesel kit, it replaces the cup with a longer one that spans that crack. Seems like a permanent fix also, where the BP is likely a permanent fix, but cracks may grow.
With the ability to rent a cup puller from Accurate, it's also $200 cheaper to go with them.
2005 F350 6.0/5r110
Gaius is offline
post #5 of 18 (permalink) Old 07-19-2016, 04:04 PM
Garage
Let us know how it goes.
post #6 of 18 (permalink) Old 07-20-2016, 01:52 AM Thread Starter
Gaius's Avatar
I will do. It looks straightforward, but I also haven't done cups before.
The dirty injector is the one that came out of #5. Any idea what is causing the discoloration/burning on the lower body? I suspect the lower o-ring is also bad (it's flat and hard) and letting diesel down into the cup? Any ideas?
2005 F350 6.0/5r110
Gaius is offline
post #7 of 18 (permalink) Old 07-20-2016, 02:06 AM
s10mike's Avatar
it looks rusty?
s10mike is offline
post #8 of 18 (permalink) Old 07-20-2016, 03:39 AM Thread Starter
Gaius's Avatar
Maybe coolant was pushing down there after the fuel pressure fell off when engine turned off?
2005 F350 6.0/5r110
Gaius is offline
post #9 of 18 (permalink) Old 07-20-2016, 09:18 AM
Garage
One of mine was the same color, but all gooey. It was gelled up fuel from a bad o-ring. Maybe yours is just at an earlier stage of this?
2004 Excursion 6.0
post #10 of 18 (permalink) Old 07-22-2016, 02:33 AM Thread Starter
Gaius's Avatar
Today I pulled the cup, and installed the longer cup and lower injector body from Accurate Diesel. This seems to be a great fix.
Sent from my SM-G930V using Tapatalk
2005 F350 6.0/5r110
Gaius is offline
