Oil Standpipe Stuck - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By codykthekilla
  • 1 Post By ascrap2003
post #1 of 7 (permalink) Old 06-06-2016, 01:53 AM Thread Starter
Famous words "Watch This"
ascrap2003's Avatar
Oil Standpipe Stuck
Doing some repairs on a 2007 F550 the bottom half of the oil standpipe is stuck, wont let go, I tried needle now. Any Ideas?
2002 F350 SuperCab SRW Lariat, Hutch Mod, EBPV Delete, Straight Pipe, Chipped
2007 F550 Crew Flatbed
My websites:
ascrap2003 is offline
post #2 of 7 (permalink) Old 06-06-2016, 02:06 AM
codykthekilla's Avatar
Garage
Re: Oil Standpipe Stuck
I use a combination of need nose vise grips, and a pry bar to get them out when they are stuck, I will clamp the tube tight enough not to collapse it and try prying if i can, if not I put the pry bar against the vice grips at the tube and hit with hammer strait up. If this does not work you will probably destroy the thing getting it out. Good luck.
Zmann likes this.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #3 of 7 (permalink) Old 06-07-2016, 12:13 AM Thread Starter
ascrap2003's Avatar
Thanx needle nose lock pliers and pry bar worked like a charm!
Zmann likes this.
My websites:
post #4 of 7 (permalink) Old 06-07-2016, 12:14 AM Thread Starter
ascrap2003's Avatar
Oil Standpipe Stuck
By the way the tip on one side of the tube the bottom half got bent about 1/8" in but it looks like the o ring should seal good use it or trash it?
My websites:
post #5 of 7 (permalink) Old 06-07-2016, 01:45 AM
Jackleg Mechanic
mastrkee's Avatar
I wouldn't chance it, unless you are willing to go back in and replace it. Not worth the trouble!!
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #6 of 7 (permalink) Old 06-07-2016, 03:26 AM Thread Starter
ascrap2003's Avatar
I'll post a pic later
My websites:
post #7 of 7 (permalink) Old 06-07-2016, 08:15 PM
Garage
If the dip stick moves freely in the tube and the spot for the oring is not damaged it will be fine.
