running weird. help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-22-2009, 11:54 PM Thread Starter
jamstoyz's Avatar
running weird. help
2 questions, 1st do you guys in the cold states take your tuners out for the winter and run stock cause i heard it wasnt good for the truck.
2nd relates to the 1st. i went ahead and took my sct out and returned to stock but now the truck runs worse than before. such as rough running with cold starts even when plugged in overnight. also the trans shifts worse with stock setting. doesnt wanna shift at all. i can turn the truck off for 10 minutes and the motors still warm but it starts blowing blue smoke and not shifting.
if i leave my sct on in the winter, only problem i gotta deal with is the rough running until its warm. shifts fine too.
Jeff
05 single cab short bed
03 turbo
sct with custom tunes from innovative
stroked injectors
afe stage 2
small mouth intake elbow
autometer boost, pyro
4.30 gear
harley head lights
recon smoked tail lights/ 3rd brake light
mb motoring 22x12 in the rear
mb motoring 20x10 up front
jamstoyz is offline
post #2 of 5 (permalink) Old 12-23-2009, 04:29 AM
Stroker67's Avatar
Re: running weird. help
I leave my SCT on in the cold, doesnt bother my truck any.
Stroker67 is offline
post #3 of 5 (permalink) Old 12-23-2009, 06:19 AM
professional slacker
alwil's Avatar
yeah makes no difference on my truck either.
Injector problems maybe?
alwil is offline
post #4 of 5 (permalink) Old 12-23-2009, 04:28 PM
Stroker67's Avatar
I would bet Injector issue or FICM
post #5 of 5 (permalink) Old 12-23-2009, 05:21 PM
alwil's Avatar
I forgot about the ficm, when mine started to go out I had really bad cold starts and then it would clear up when warm.
alwil is offline
