Low oil pressure problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 12-22-2009, 01:12 PM Thread Starter
PUTZMAN23
PUTZMAN23's Avatar
Question Low oil pressure problems
have a 6.0L with 0-5 oil psi at idle and 20psi and 3000rpms. have already changed oil pump and pressure relief valve and oil filter housing. still having the same issue. looking for some help here.
2006 F250 w/6in lift
20" XD Rockstars
K&N air intake and 4in turbo back pipes
SCT with custom tunes from FCDP
ARP Studs
EGR Delete
Coolant Filter
PUTZMAN23 is offline
post #2 of 21 (permalink) Old 12-22-2009, 11:00 PM
professional slacker
alwil's Avatar
Re: Low oil pressure problems
You must be talking about the low pressure oil system?
alwil is offline
post #3 of 21 (permalink) Old 12-22-2009, 11:04 PM
Super Hauler!
Super_Hauler's Avatar
Super_Hauler is offline
post #4 of 21 (permalink) Old 12-22-2009, 11:23 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Your lpop might be going bad, its down on the front cover, behind the damper. Its a pain in the rear to get to but if you have the tools you can probably do it.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #5 of 21 (permalink) Old 12-22-2009, 11:46 PM Thread Starter
PUTZMAN23
PUTZMAN23's Avatar
We did change the lpop and relief valve. at an idle the pressure will jump from 0 to 10 or so even with the live gage installed. someone told me there is a gasket that could have blown out between the 2 halfs of the block. i did not know there was 2 halfs or isn't their?
20" XD Rockstars
ARP Studs
EGR Delete
Coolant Filter
post #6 of 21 (permalink) Old 12-23-2009, 12:13 AM
Did you replace the front cover? Was it still good?
06 F-250 ECSB 4x4, 6.0 - sold - little
2010 F-250 CCSB 4x4 6.4 Lariat Ultimate-few mods, but it is FAST!!!!
fuekear is offline
post #7 of 21 (permalink) Old 12-23-2009, 12:49 AM
Are you running an aftermarket oil filter? Also as mentioned above, what did the front cover behind the oil pump look like?
Jay03GT is offline
post #8 of 21 (permalink) Old 12-23-2009, 03:18 AM
alwil's Avatar
Originally Posted by powerstrokinc View Post
are you as productive on the other side of the computer as you seem from my side?
alwil is offline
post #9 of 21 (permalink) Old 12-23-2009, 03:37 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
If you have a large enough leak on the high side. It will drain the low side. Do you have a way to monitor IPR duty cycle to see if it is trying to keep up?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #10 of 21 (permalink) Old 12-23-2009, 06:10 AM
CanadianRedneck's Avatar
could have an oil gallery plug that fell out also. two of them are behind the front cover and another two behind the flywheel and rear cover. I have seen them fall out before and they cause a low oil pressure problem
2005 F350 Crewcab 4x4 6.0L
64mm turbo, NADP race tranny, tuning by Eric at Innovative Diesel
2004 F250 4x4 6.0L
Work in progress.......
EDE heads, cam, pistons, hybrid injectors, Hypermax rods,
2 really big turbos and a whole bunch of other crap to come.....
Tuning by Innovative of course!
CanadianRedneck is offline
