Ways fuel gets into engine oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-20-2009, 10:19 PM Thread Starter
Are leaky injectors the only way?
Tammac is offline
post #2 of 6 (permalink) Old 12-20-2009, 10:56 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Ways fuel gets into engine oil
The o-rings on the body. Internally. And fuel wash in the cylinder. Or worst case a crack large enough for the fuel to get out of the head.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 6 (permalink) Old 12-22-2009, 03:14 AM
SamW's Avatar
probibly internally. I just went through that one . I was changing the oil every other week. be sure that it doesnt get too dilute or you get the stock injectors back in as soon as possable. says on the RCD site they wont warrenty injector damage due to fuel in oil, but how does it get there in the first place...not sure on other companies policies. kind of a chicken vs the egg argument. mine are being shipped out tomorrow so we will see how well they stand to it. good luck with yours
2006 F250 CCSB
6.
SamW is offline
post #4 of 6 (permalink) Old 12-22-2009, 01:36 PM Thread Starter
I don't have my stock ones, they were sent back as cores! Im going with the external side of it because I installed them :-), so, if no shop has time I'm tearing it apart AGAIN!!
Tammac is offline
post #5 of 6 (permalink) Old 12-22-2009, 10:28 PM
SamW's Avatar
mine started from day one and it was an internal leak, I just didnt notice right away. shop tested for external leaks by putting dye in the fuel and idle the truck with the valvecovers off in the dark and using a blacklight to find the fuel. I made the mistake of sending a perfectly good set of cores back next day. should have held onto them until the last minute. whos injectors?
2006 F250 CCSB
6.
SamW is offline
post #6 of 6 (permalink) Old 12-22-2009, 10:54 PM Thread Starter
Originally Posted by SamW View Post
.............whos injectors?
won't say whose, probably not internal
Tammac is offline
