Cooing system pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 17 (permalink) Old 03-06-2016, 02:27 PM Thread Starter
PSN
Msolem's Avatar
Garage
Hello everyone i'm just curious on when everyone's opinion is on the proper cooling system pressure to be running. In the past my truck is run about 8 pounds almost all the time lately it's been running 13 to 14 but never any higher. I'm just curious if I could be boiling coolant somewhere at some point, I think the head gaskets are still solid.
2004 6.0 240000
Stock intake
Stock exhaust
Deleted factory oil cooler and installed high performance setrab with electric fans
New heads and injectors
Arp studs
Coolant filter
Gauges pyro, oil temp, coolant temp, boost, coolant pressure
Cat elc coolant and filter
Blue fuel regulator spring upgrade
Msolem is offline
post #2 of 17 (permalink) Old 03-06-2016, 04:14 PM
Administrator
Zmann's Avatar
Re: Cooing system pressure
Bump and I moved this from the library to the 6.0 section so you can actually get replies now ( common mistake )
you cap may be bleeding off at 14 vs 16 you may want to keep a close eye on this
what tunes do you run ?
whats your other temps out of curiosity /?
curious on your oil cooler also
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #3 of 17 (permalink) Old 03-06-2016, 06:38 PM Thread Starter
PSN
Msolem's Avatar
Garage
Going down the road after cruising at 60 miles an hour for about an hour my temperatures will be a little bit different than most because I don't have a factory oil cooler, it's a separate cooler mounted directly behind the t-case. It's driven off of it thermostatic switch so after driving for an hour oil temp is right about 200, water temperature is 185, pyrometer is 610, boost is 7 pounds. With the oil cooler set up I have oil temperature will stay between 180 and 210.
I would like to post pictures on the set up that I have but I cannot figure out how to do it.
2004 6.0 240000
Stock intake
Stock exhaust
Arp studs
Coolant filter
Msolem is offline
post #4 of 17 (permalink) Old 03-06-2016, 06:48 PM
Administrator
Zmann's Avatar
pics from a website is easy just use the postcard looking icon at the top of the dialogue box and add the address
from a computer you will need to go down and click the advanced button then manage attachments and find them on you computer to upload
if on a phone I am not sure how that works
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 17 (permalink) Old 03-06-2016, 06:49 PM
Administrator
Zmann's Avatar
your oil cooler is air to oil but not in the airflow like a radiator ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 17 (permalink) Old 03-06-2016, 07:38 PM Thread Starter
PSN
Msolem's Avatar
Garage
Here are some pictures of the oil cooler and my gauges after about an hour drive.
2004 6.0 240000
Stock intake
Stock exhaust
Arp studs
Coolant filter
Msolem is offline
post #7 of 17 (permalink) Old 03-06-2016, 07:54 PM
Administrator
Zmann's Avatar
what did you use to redirect the oil to the remote cooler ?
van style filter adapter ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 17 (permalink) Old 03-06-2016, 08:24 PM Thread Starter
PSN
Msolem's Avatar
Garage
I am using components from the E-series oil filter setup. it works well but if I ever have the cab off I will be refining the setup to use the E-series oil lines. it would really clean it up and decrease oil capacity, right now my dry fill oil capacity is about 19qts.
Zmann likes this.
2004 6.0 240000
Stock intake
Stock exhaust
Arp studs
Coolant filter
Msolem is offline
post #9 of 17 (permalink) Old 03-06-2016, 08:50 PM
"Slap hands slap hands"
FlossyB's Avatar
From a phone or iPad I have to use photobucket. It works perfectly. Took me a year to figure it out but once I did it was simple. Either way subs to this thread.
Zmann likes this.
JB
FlossyB is offline
post #10 of 17 (permalink) Old 03-06-2016, 10:17 PM
Administrator
Zmann's Avatar
nice DIY oil kit !
DTR's Donation page
RIP DTR Ron
Zmann is offline
