Using anti freeze - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-01-2009, 01:43 PM Thread Starter
justintimemoto's Avatar
Using anti freeze
well i got my truck back about a week ago w new heads and head gaskets..looked at when i got home it was half full.and while cleaning my truck today i looked at and it was below minimum like 1/4 below minimum.... have not really drove the truck much since last week maybe 400 miles at tops but that's it......and it was starting really good before glow plugs fires right up now it cranks a little longer on a warmer about 45 degress...any ideas im hoeing it not the head gaskets again...but there was faint white smoke coming out just a little but.....idk any ideas its a 07 6.0 mbrp 4"turbo back banks intake..and yes i suck at typeing as seen on the title
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
justintimemoto is offline
post #2 of 13 (permalink) Old 11-01-2009, 01:50 PM
gracing's Avatar
Re: useign anti freeze
did you check to see if you had any visible leaks at the radiator and heater hoses?
gracing is offline
post #3 of 13 (permalink) Old 11-01-2009, 02:02 PM Thread Starter
i will do that in a little bit...but think its a possiblity that the head gaskets are bad
post #4 of 13 (permalink) Old 11-01-2009, 06:15 PM
"resident smarty pants"
It is normal for the degass bottle levels fluctuate quite a bit. It could be as simple as that - keep an eye on it and don't drive it if you see a lot of white smoke!
Do you still have the EGR system?
Mark
bismic1 is offline
post #5 of 13 (permalink) Old 11-01-2009, 09:38 PM
fordpowerf450's Avatar
i guess its possible its the gaskets. would probly have to be an installer error tho. maybe they didnt get them torqed right? and when they did it did they do anything with the block surface? my degas bottle moves quite a bit to tho maybe just keep an eye on it for a while if it continues to get lower then look into a egr. and make sure to check all your coolent lines as stated earlier.
08 6.4 cc/lb.
2006 6.0 just stock..
1960 f100, 12v project.
fordpowerf450 is offline
post #6 of 13 (permalink) Old 11-01-2009, 11:01 PM
Harry Callahan
Re: Using anti freeze
There could have been an air pocket in the system somewhere, I would just keep an eye on the level and log any addition of coolant, time you added it and amount added. If you still have egr cooler maybe pull the valve and check for water.
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
post #7 of 13 (permalink) Old 11-01-2009, 11:38 PM
Snake Oil Salesman
mattr66's Avatar
Coolant levels on a fresh build tend to drop over the first few days as all the little air pockets get worked out of the water jackets. Now if it is sucking the bottle dry every week then that is another story.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #8 of 13 (permalink) Old 11-02-2009, 02:10 AM
My sentiments EXACTLY!! I think it'll settle in for you, it's just fillin' in the air pockets.
Mods to be listed after truck is running.......
Tammac is offline
post #9 of 13 (permalink) Old 11-02-2009, 05:56 AM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
justintimemoto, I had my ARP's put in and my truck puked a bunch of coolant on the ride home from the dealer. It was just overfilled... it went away for a while... now it still pukes like crazy. I just added a gallon of coolant/water the other day and it didn't even bring it up to the min line on the tank. I do believe my headgaskets are shot again, with the ARP's installed.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
post #10 of 13 (permalink) Old 11-02-2009, 08:16 PM Thread Starter
yea i still got my egr.......they did a pressure check on it today at the dealer and they said its fine and they will check it again when i bring it back to get another thing fixed......thanks
