turbo issue? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-19-2015, 05:16 PM Thread Starter
Airman
turbo issue?
Having continuous noise from engine I believe to be turbo bark under light acceleration not when lifting from wot. Early 04 f250 6.0 so basically 03 new egr valve new map sensor recently cleaned turbo cleaned iat2 cleaned map port and hose cleaned mas sensor getting p132b and sometimes P0401. Pressure tested intake tubes with 20 psi holds pressure Any ideas? I have a video I'll see if I can figure out how to post it.
airmanaz is offline
post #2 of 12 (permalink) Old 04-19-2015, 05:20 PM Thread Starter
Airman
airmanaz is offline
post #3 of 12 (permalink) Old 04-23-2015, 05:26 PM Thread Starter
Airman
Re: turbo issue?
Anyone? I have seen multiple threads on this but none have how it was fixed.
airmanaz is offline
post #4 of 12 (permalink) Old 04-23-2015, 07:46 PM
Re: turbo issue?
Did you get a video posted yet? That might help out (or at least get a few more responses).
post #5 of 12 (permalink) Old 04-24-2015, 04:01 AM Thread Starter
Airman
Re: turbo issue?
https://youtu.be/Jd-0MCxxpJs
airmanaz is offline
post #6 of 12 (permalink) Old 04-25-2015, 12:53 AM Thread Starter
Airman
Re: turbo issue?
Twice it said waiting for moderator and it never showed up. Maybe I'm doing it wrong?
airmanaz is offline
post #7 of 12 (permalink) Old 04-25-2015, 05:10 AM
Re: turbo issue?
Host it on youtube and just share the link here.
post #8 of 12 (permalink) Old 04-25-2015, 02:47 PM Thread Starter
Airman
airmanaz is offline
post #9 of 12 (permalink) Old 04-25-2015, 06:46 PM
Re: turbo issue?
That is very strange. What does your MAP look like when it's doing that?
post #10 of 12 (permalink) Old 04-26-2015, 03:37 AM Thread Starter
Airman
Re: turbo issue?
Don't have a way to check it yet. SCT arriving Wed. Will monitor with that. Codes keep coming and going, turbo constantly cycles at idle. Hoping I can figure it out with the SCT. Have several tunes from Quick Tricks coming I want to try esp. Looney Wild pct. Yes it's studded
airmanaz is offline
