6.0 starting issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-16-2015, 11:03 PM Thread Starter
6.0 starting issues
ok i know there has been alot of write ups on this. i seem to have a unique situation. ok i have a 2003 excursion with a 6.0 last weekend it was idling in my driveway and just died like it ran out of fuel. i replaced the fuel pump, filters, the IPR and the IPC , i ran a diagnostic on it.. here is my values. also checked ficm relay and turbo for stuck impeller.
IPR key on 15%
IPR start 80%
hpop start psi 585psi
ficm voltage
M power key on 49%
M power start 48%
V power key on 11.9 v
V power start 10.5v
L power key on 11.9v
L power start 10.5v
so everything is withing parameters of where it should be but yet it wont start was running great up to this point , no issues
what am i missing ???
reaper75032 is offline
post #2 of 13 (permalink) Old 04-17-2015, 03:03 AM
Re: 6.0 starting issues
What are you using to view the data? Scangauge II? If yes, you might FICM sync. Maybe it's not? Just an idea.
post #3 of 13 (permalink) Old 04-17-2015, 03:59 PM
She's ALIVE AgAiN!!!
afFORDable's Avatar
I would start simple. Check your grounds, electrical connections, battery connections. Even just being loose, those could cause some starting issues that youll chase for ages.
The old adage "Keep it simple, stupid" is still a grand thought to follow. Especially BEFORE you start dumping more money into it.
Jus my $.02
Keep us updated please.
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #4 of 13 (permalink) Old 04-17-2015, 04:37 PM
Also, you might want to check and clean the ground connection on the block. They are known to be loose and cause problems
03 Excursion, Banks turbo back, K&N intake, SCT sf2, Scangauge 2, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #5 of 13 (permalink) Old 04-17-2015, 05:16 PM
afFORDable's Avatar
^+1
I bought a ranger (I know, not a diesel) and one day driving to work, I made a right turn and it just shut off on me. Everything still worked, electronically, but the motor would not start. Turned out to be a body to block ground that I MacGuyver'd together (using a pocket knife, no less) and she fired right up and carried me to work.
It usually is the little things.
post #6 of 13 (permalink) Old 04-17-2015, 08:37 PM Thread Starter
All grounds are good, all connectors have been pulled off and put back on. Using torque pro app. And the motor cranks. Just wont fire off. Like it has no fuel. But fuel bowl fills. Something is keeping the injectors from firing. Checked ficm relay. It's good.
post #7 of 13 (permalink) Old 04-18-2015, 03:22 AM
... Sync?
post #8 of 13 (permalink) Old 04-20-2015, 01:40 AM
did you get your truck running?
post #9 of 13 (permalink) Old 04-21-2015, 07:33 AM Thread Starter
not yet , injectors do the buzz test. changed cam and crank sensors, no help... swaped ficm from another 2003, no help. hpop is now getting 1500 psi on crank, still no start . doing an air test on hpop system tomorrow. see what comes of it
post #10 of 13 (permalink) Old 04-22-2015, 03:50 AM
being you have an 03, I'm thing your pump as failed. Well kinda! I thing your swash plate has moved out of timing. I hope this youtube vid helps you understand. Pat talks in the vid how if swash plate isn't in time the engine will not run.
Powerstroke 6.0 7.3 hpop technical how-to - YouTube
