Another "what else?" thread. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-16-2015, 10:40 PM Thread Starter
Weatherlite's Avatar
Garage
Well, I decided to do head gaskets as that was the only thing we could think of which could be causing my issues and it's a good thing because they were shot. Now that I'm in that far, is there anything else, short of a full rebuild, that I could or should be doing?
2004.25 MY engine. EGR delete. New, rebuilt, HPOP. VERY thorough reverse flush of cooling system, restore, distilled water, etc. Oil cooler deltas are 3-4 degrees at highway speeds after half an hour of running. Changed all o-rings in HPO system to exclude standpipes because you can't get to em without tearing engine apart. Full oil cooler rebuild. Turbo reconditioned. (may be doing a rebuild....have to determine if the oil leak is internal of if my CCV catch can isn't working as it should. Upgraded alternator. Good ICP and IPR. Good injectors. Good wiring. I think that's about it.
So, anything else I should be looking at or replacing since I've got the heads off, etc? One thing I don't know is if I can reuse the glow plugs. They appear in good condition and I have never had any codes on them.
Weatherlite is offline
post #2 of 9 (permalink) Old 04-16-2015, 11:28 PM
Re: Another "what else?" thread.
If you ever thought about injectors now would be a good time.
lenzhotrod is offline
post #3 of 9 (permalink) Old 04-16-2015, 11:32 PM
matthewd11's Avatar
replace as many injectors as you can afford.
matthewd11 is offline
post #4 of 9 (permalink) Old 04-17-2015, 03:05 AM
"resident smarty pants"
shorter pushrods?
Mark
bismic1 is offline
post #5 of 9 (permalink) Old 04-17-2015, 05:59 AM Thread Starter
Garage
Originally Posted by bismic1 View Post
shorter pushrods?
post #6 of 9 (permalink) Old 04-17-2015, 06:00 AM Thread Starter
Garage
Considering I'm going broke on this job, I can afford a grand total of zero injectors. lol I've never gotten any codes or had issues other than light stiction in winter (before I started running Archoil) so I should have a few years on em. Those aren't difficult to replace thankfully, so when I do have to do it, I won't be upset over the amount of work.
post #7 of 9 (permalink) Old 04-17-2015, 01:54 PM
Jackleg Mechanic
mastrkee's Avatar
I'm curious about your statement regarding the standpipes. If the heads are off aren't the pipes out as well? Or are they set up different than my 06?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #8 of 9 (permalink) Old 04-17-2015, 03:54 PM
She's ALIVE AgAiN!!!
afFORDable's Avatar
The early 04 stand pipes SHOULD be off if the heads are off. Otherwise...How did you get the heads off? The stand pipes run through the heads.....at least that's how they are set up on mine......??
If this is not fact, please, enlighten us.
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #9 of 9 (permalink) Old 04-18-2015, 04:06 AM Thread Starter
Garage
CRAP!!! I meant branch tubes, not stand pipes! lol
