p0279 inj lo cy 7 / changed injector still not right - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-16-2015, 12:46 PM Thread Starter
smokinstroke's Avatar
my sct programmer scanned this DTC about a week ago,i changed out injector number 7 last night and the truck still isnt running right.it runs and drives but has a vibration while running almost like its miss firing. any help?
04 f-350 sct x2, 3in lift w/35in toyo m/t and 20x12 weld dune 8, recon cab lights, straight piped, FCDP egr delete,06 front end and 08 tailgate
smokinstroke is offline
post #2 of 2 (permalink) Old 04-19-2015, 09:43 PM
'04psthrottlejockey
'04psthrottlejockey's Avatar
Re: p0279 inj lo cy 7 / changed injector still not right
You may need to pressure test your hpop system. An oil leak anywhere in the system can cause injector codes to pop up. Before you go to that trouble though unplug the injector and make sure the pond in the four wire harness for the injector didn't push in and the wires in the main harness aren't chafed or damaged in any way.
'04 F250 6.0 RCD EGR delete, diamond eye 4"turbo back, AFE stage 2 cold air intake, Livewire TS, Warren Diesel Injection 190cc stock nozzle injectors with upgraded solenoids, FASS Titanium series fuel pump. 4" procomp suspension lift with extra overloads on rear.
'04psthrottlejockey is offline
