Broken clip....problem? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-16-2015, 03:51 AM Thread Starter
Weatherlite's Avatar
Garage
As I was pulling my heads apart to pull em for a head gasket job, I noticed one of the plastic retaining clips on a rocker arm was missing a small piece. I spoke with a local mechanic who only does diesels and he stated these plastic clip things are really only for assembly and once everything is torqued down they serve no purpose. Attaching a pic of the one with it missing and of another with the piece intact, just so you can see what I'm talking about. Is this an issue or am I ok?
Weatherlite is offline
post #2 of 6 (permalink) Old 04-16-2015, 12:27 PM
matthewd11's Avatar
Re: Broken clip....problem?
if its missing a clip to hold the ball in then buy a new rocker arm assy.
matthewd11 is offline
post #3 of 6 (permalink) Old 04-16-2015, 10:29 PM Thread Starter
Garage
No, just the tab at the top broke off. The main part of the clip is still intact. It's the middle pic above.
post #4 of 6 (permalink) Old 04-17-2015, 02:11 PM
Jackleg Mechanic
mastrkee's Avatar
I broke several clips when I took my heads off. yours appear to be made different than the ones used on my rockers. They were about 4 bucks apiece to replace and I did replace mine so I knew the motor was correct.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #5 of 6 (permalink) Old 04-18-2015, 03:57 AM Thread Starter
Garage
I've never seen these sold before. Do you know what the nomenclature is so I can look em up on a Ford parts site? If they're that cheap I may as well replace it.
post #6 of 6 (permalink) Old 04-18-2015, 06:06 PM
Jackleg Mechanic
mastrkee's Avatar
This is the clip used on my truck. As I said it appears to be somewhat different from yours. I contacted sunrise ford about them and I'm sure you could do the same. I actually purchased them from my local dealer in the end.
Jeff
mastrkee is offline
