2007 6.0 Boost Problems. Please Help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-16-2015, 03:29 AM Thread Starter
So I just bought an 07 F250 6.0 yesterday. It has a K & N intake on it and then today I installed an Edge Evolution CS and I noticed that the truck tops out at 20 psi of boost on both the CS screen and my trucks stock boost gauge. I've been reading that these trucks typically hit 27-28 psi at WOT. Any ideas as to what the issue is if any?
07Super is offline
post #2 of 8 (permalink) Old 04-16-2015, 07:15 PM Thread Starter
Re: 2007 6.0 Boost Problems. Please Help!
Bump
07Super is offline
post #3 of 8 (permalink) Old 04-16-2015, 07:57 PM
Slated4Greatness's Avatar
Check your up pipes and IC boots as well as the plastic IC tube on the drivers side.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #4 of 8 (permalink) Old 04-17-2015, 04:41 AM Thread Starter
You mean make sure all the clamps are nice and tight and there are no leaks?
07Super is offline
post #5 of 8 (permalink) Old 04-17-2015, 05:09 AM
cfherrman's Avatar
Look for fresh oil on the outside of the boots if you still have factory ccv
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #6 of 8 (permalink) Old 04-17-2015, 05:46 AM
Weatherlite's Avatar
Garage
Pretty much. Sometimes the up pipes crack, though usually you can hear a sound similar to a jet engine when this is the case. Also, they may be loose on the manifolds or the connecter on the turbo may not be lined up right. As for the CAC boots, I found the best way to look for cracks in em is to take them off and bend/twist em. The crack will usually appear if there is one. And of course, making sure they are tight on the tubes is important.
Weatherlite is offline
post #7 of 8 (permalink) Old 04-18-2015, 03:58 AM Thread Starter
Ok i will look through everything and see if I can find anything .... I did more testing with the tuner and at most the boost peaks at 25-26 psi but it usually sits around 20-22 psi
07Super is offline
post #8 of 8 (permalink) Old 04-18-2015, 08:42 PM
Jackleg Mechanic
mastrkee's Avatar
That's probably all your going to see it the truck is running a stock tune. IMO
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
