Machining for studs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-14-2015, 10:08 PM Thread Starter
Weatherlite's Avatar
Garage
Just a quick question. While talking to the machine shop today, he told me since I am studding the truck (already did but now have to get gaskets re-done) he will machine the head for the 18mm dowel to go deeper. I have never heard of this before. I chose this machine shop because I couldn't find one locally that would do a diesel. This shop does about 8 sets of 6.0 head a week and builds full motors, so I would think he has some knowledge. Anyway, he said he found that the dowels are actually a hair too long when using studs, which doesn't allow even clamping force. He showed me by putting a head on a block without the gasket and measuring the distance, then comparing it to the head gasket thickness. I wouldn't have thought this could be an issue, but it did appear so. NO extra charge for it so I don't think he's just trying to convince me for a profit reason.
Anyone ever seen something like this?
Weatherlite is offline
post #2 of 8 (permalink) Old 04-14-2015, 11:15 PM
Stevenmc08's Avatar
Re: Machining for studs?
I've never seen this or heard of it but if the dowels are too long for the head to bolt down good then it makes sense. Is he wanting to machine the head or the dowels?
2003 F250 lariat, 6.0, CC/SB, FX4, RANCHHAND Legend series bumper, blue spring, straight pipe with cat delete, 285 BFG A/Ts, B&W gooseneck, and a lot of stock parts for now
Stevenmc08 is offline
post #3 of 8 (permalink) Old 04-15-2015, 12:40 AM
Administrator
Zmann's Avatar
lol
jig up a head or buzz the dowel but regardless i have never heard of this one
it would take ten seconds to verify
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 8 (permalink) Old 04-15-2015, 01:33 AM Thread Starter
Garage
I thought about it for a while and I think he meant after machining for flatness. This would make sense if you had to take a decent amount off the head and the dowel wasn't seated all the way down, etc. Either way, I'll be measuring my dowel and the recess in the head to see what I've got. Just thought I would bring it up.
post #5 of 8 (permalink) Old 04-15-2015, 01:59 AM
Administrator
Zmann's Avatar
thanks !
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 8 (permalink) Old 04-15-2015, 02:22 AM Thread Starter
Garage
Forgot to address this. He puts the machining on the head since you never know if a dowel will be replaced in the future.
post #7 of 8 (permalink) Old 04-15-2015, 02:51 AM
Jackleg Mechanic
mastrkee's Avatar
That's an interesting aspect of milling 6.0 heads since Ford says that they are not to be machined. I just had mine done and the machinist didn't mention it. This particular shop came highly recommended by several people in my area that have a lot of stuff machined and I trust their judgment. It's definitely something to be looked at! Now I'm wondering if all the work I just did studding my truck will be in vain.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #8 of 8 (permalink) Old 04-15-2015, 05:19 AM Thread Starter
Garage
It may just be something they ran across a couple times and now he does it as a matter of habit....just in case. Who knows?!
