Unstoppable Turbo Leak HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-14-2015, 05:20 PM Thread Starter
So this is my fourth time taking the turbo off and reinstalling it trying to get that "perfect" seal. It will be ok for a little bit then P0299, Turbo Farts, Backpressure sensor, etc etc. . . I tried closing the clamp v with vice grips a bit as it is a stout mo fo. That worked for a few days and now the leak is back. I tried copper gasket, that powderd and decorated my valley. I need professional help!!!!
2004 F250 Crew Cab, Long Bed, 4X4 Lariat. Sinister EGR Delete, Coolant Filtration. Edge Evolution CTS, Powermax Turbo.
HankdaTank is offline
post #2 of 4 (permalink) Old 04-15-2015, 02:51 AM
cfherrman's Avatar
Re: Unstoppable Turbo Leak HELP
Do not use the clamp to do anything, leave it off and around the turbo so you can see the flanges. Loosen the bottom nut on both exhaust manifolds and put a ratchet strap hook in the y of the collector. Hook the ratchet in by the pass headlight and tighten it down. Use your hand to feel around the flanges and see which way you need to go and push it that way. When its lined up you will know it there will be no gap, it will look perfect. The clamp just holds it in place it does not clamp it together.
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #3 of 4 (permalink) Old 04-15-2015, 03:09 AM
Jackleg Mechanic
mastrkee's Avatar
Leave the manifold ends very loose, take off the down pipe and line up the collector and clamp it to the turbo. then assemble the other parts.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #4 of 4 (permalink) Old 04-17-2015, 03:42 PM Thread Starter
thanks guys
