No auto 4x4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-13-2015, 09:41 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
No auto 4x4
I have an automatic lariat with the 4x4 switch on the dash. When I switch it to 4x4, it does not engage the front at all. If I get out and lock the hubs, everything works fine. Any suggestions?
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #2 of 4 (permalink) Old 04-14-2015, 05:58 AM
IIvonnyII's Avatar
Re: No auto 4x4
they are vacuum actuated. do you hear anything when you turn the switch? when were your balljoints changed last? the axle seals tend to dry out / crack causing a leak. not allowing them to lock automatically
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #3 of 4 (permalink) Old 04-14-2015, 12:20 PM
cfherrman's Avatar
Re: No auto 4x4
Turn on the vents to full blast, turn on 4x4, if the vents switch to the defrost you have a vacuum leak. You have to check the lines to find it or you can use a drill bit driver to plug a certain hole that i cant remember to make them perma manual
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #4 of 4 (permalink) Old 04-14-2015, 04:40 PM
Administrator
Zmann's Avatar
Re: No auto 4x4
if the vacuum doesn't work they are "perma manual" lol
common for the ESOF solenoid to fail along with the mentioned lines and knuckle seals
DTR's Donation page
RIP DTR Ron
Zmann is offline
